D16z6 with 2 dipsticks...
Old 09-02-2013, 08:55 PM
FairlyImprudent's Avatar
Default D16z6 with 2 dipsticks...
Just bought a d16z6 block for a good deal. I looked at it at home and realized it has two dipsticks. One where it's supposed to be. And one where the d16yxs are located. Which from what I read, means it has the d16yx oil pump. I don't know who's the dumbass who set that up.. Let's hope it doesn't have the y7/8 crank in it also...
So my question is, should I get a z6 oil pump? Or is it not a big deal to worry about? I plan on boosting this in the near future. And I don't know if I should worry about the oil pressure and this issue. I also found out the two pumps are near identical other than the dipstick. So I'm mostly just focusing on the factor of the two dipsticks
Old 09-03-2013, 01:51 AM
TravisBiggie's Avatar
Default Re: D16z6 with 2 dipsticks...
Pics for luls
Old 09-03-2013, 02:27 AM
NZXTInerTia's Avatar
Well see, when you're going twice the speed. You need twice the dipstick.
Old 09-03-2013, 03:32 AM
dcmatt's Avatar
The y8 oil pump is horrible not the crank. My understanding is that's why the y7/8's were so prone to spinning a bearing.
Old 09-03-2013, 03:42 AM
The Grumpiest
grumblemarc's Avatar
Wrong. You understand backwards.
Old 09-03-2013, 07:31 AM
I guess someone thought it would be a good idea to double check their oil lol. I'll upload a pic when I get home later today.
So is it a bad idea to boost with 2 dipsticks lol?
Old 09-03-2013, 07:38 AM
kyden's Avatar
boost has nothing to do with a dipstick.
Old 09-03-2013, 09:25 AM
dcmatt's Avatar
Oh really? So the crank out of a z6 is better then a y8?
Old 09-03-2013, 09:56 AM
The Grumpiest
Absolutely.
Old 09-03-2013, 10:10 AM
Garage 808 Hatch's Avatar
I did the opposite on my old vitara build. y7 block and a z6 pump. dip stick delete
Old 09-03-2013, 10:30 AM
Keyboard Humorist
4drEF's Avatar
Both crank and oil pump aren't as good as the Z6.
The Y8 pump puts out about 30% less cfm - you can verify this in the shop manual.
The Y8 crank has one oil hole per journal while the Z6 crank has 2 oil holes per journal.
Old 09-03-2013, 12:17 PM
Well then it looks I'll be getting a new pump. I'm feeling hesitant to check the crank lol.
And to the other response about dipsticks having no effect on turbos. I read something about the oil pressure with turbos and why I should be concerned about the dipstick. But there's no sense I can make of that. Now that's besides the point since I'll be getting a new one.
And I still intend on posting pictures when I can for amusement
Old 09-03-2013, 12:30 PM
allshowfxt's Avatar
haha the fact that this had to be posted.
Old 09-03-2013, 12:49 PM
kyden's Avatar
what does oil pressure have to do with a dipstick? the dipstick only has 1 purpose.
Old 09-03-2013, 12:57 PM
No **** it only has one purpose lol. It still has to hold in the pressure though. I don't know why what I read said that about the dipstick and that it could be a problem. I just read it on this forum or d series so I had to ask
Old 09-03-2013, 01:04 PM
92cxyd's Avatar
It would give ya options if your future plan includes running a turbo manifold that would make it hard impossible to check your oil.
If you have a good OEM y8 oil pump get it ported and that should work no need to buy another pump, unless damaged.
As for the crank if you are not build a 300bhp+ setup the y8 crank will work if you have a port y8 pump.
Old 09-03-2013, 01:30 PM
Yeah I thought about that. I'll just have to wait and figure it out. I just don't like the thought of having two. And I haven't even had time to check the crank yet.
Here's the picture for laughs. Two dipsticks for one dipshit
Old 09-03-2013, 01:35 PM
Freemananana's Avatar
Attachment 335450
You probably get a lot of guys eyeing up your dipsticks.
Old 09-03-2013, 03:41 PM
xile6's Avatar
Just tell them its twin dip lol
But yea looks like a y pump on a z6.
For those that are fighting the z6 has better oiling over the y motors. Case and point.
Old 09-03-2013, 03:45 PM
Who is Mr Robot?
wantboost's Avatar
Y8 crank and pump suck. Ask me how I know.
Oil pump failed, spun every bearing even spun the cam in the head
Old 09-03-2013, 03:56 PM
bgdriver's Avatar
It has a y series aluminum pan too then?
Old 09-03-2013, 04:45 PM
Twin dip for twin turbo yo!
I swear I just read that somewhere yesterday. Literally just about the exact same phrase. Were they acl race bearings too? I could not imagine the feelings when taking apart the block to see that haha
Yeah. I suppose this means the oil pump goes with the oil pan? I never thought much of that when I saw it was a y pan. Wasn't worried though. I only paid $47 for the short block
Old 09-03-2013, 06:36 PM
Not sure how important the bolts for the oil pump part. I have the absolute worst vocabulary memory. But yeah, half the oil pan studs were bolts. So I'm assuming a couple of them were from there.
The good news is I have a z6 crank
Old 09-03-2013, 06:37 PM
jimbo slice's Avatar
Y8 pump needs y8 pan.
Z6 and d15's are interchangeable.
I think the y7 has a steel pan but is the same fitment as the y8.
Old 09-03-2013, 07:05 PM
I wish the d15 pumps were interchangeable also. Well at least I have a pan to replace it with then
Quick Reply: D16z6 with 2 dipsticks...
