ignition wires. which is which? (97 del sol si)
Old 08-27-2013, 09:23 AM
mish__'s Avatar
Default ignition wires. which is which? (97 del sol si)
So on the interwebs I got...
12V CONSTANT WIRE WHITE
12V IGNITION WIRE BLACK/YELLOW
STARTER WIRE BLACK/WHITE
ACCESSORY WIRE YELLOW
but after blowing an ignition fuse and power doors/windows not working... I checked the side of the wires on the cylinder and it reads...
Acc =white/black
Batt = white
Ig1 = black/yellow
Ig2 = yellow
any input before I set my car on fire? Thanks.
Trying to install a push start.
Old 08-27-2013, 05:21 PM
teamXteg's Avatar
Default Re: ignition wires. which is which? (97 del sol si)
https://honda-tech.com/forums/showth...button+install
^^ this is a pretty detailed push button install DIY i found a while back.. hopefully it helps
Shaynepolevault
01-26-2008 09:05 AM
lsvtek
Audio / Security / Video
10
08-23-2006 08:56 PM
HamiltonRex
14
08-09-2006 06:07 PM
BoostedH23a1
11-03-2002 07:12 AM
Quick Reply: ignition wires. which is which? (97 del sol si)
