Anybody know how to get a 13x8 wheel on a ITR 5 lug set up.
Old 08-26-2013, 01:49 PM
LS-VTEC-TURBO-EF9's Avatar
Default Anybody know how to get a 13x8 wheel on a ITR 5 lug set up.
Going to drag race . Hoping you all had some insight on how I can get them to work.
Weather it be changing the disc or modifying the bracket or even fitting a gsr caliper. Anyone have any ideas?
Thanks in advance!
Old 08-26-2013, 02:37 PM
AllMotorRP's Avatar
Default Re: Anybody know how to get a 13x8 wheel on a ITR 5 lug set up.
What.... Why?
Old 08-26-2013, 03:01 PM
FlewByU352's Avatar
I no longer wish to live on this planet.
Old 08-26-2013, 03:06 PM
Originally Posted by AllMotorRP
What.... Why?
So I can run a 13x8x23 slick which is lighter and more effective vs a 15" slick.
Old 08-26-2013, 03:07 PM
Relax hard parkers its only temporary for drag racing.
Old 08-26-2013, 04:12 PM
kevinthefawker's Avatar
Just stick with the 4x100 you will have more options for wheel setups
Old 08-26-2013, 06:42 PM
FlewByU352's Avatar
Uh what? The cars didn't come like that. And swapping hubs from drag racing seems like the most asinine thing.
Old 08-26-2013, 06:54 PM
VegaS10's Avatar
Extended studs and spacers?
Maybe?
Just throwing out an idea...
Old 08-26-2013, 06:56 PM
highroller54's Avatar
I have noticed that the newer five lug civics have a fairly small rotor/caliper setup. I always wanted to try and put a set on for this exact reason.
Old 08-26-2013, 08:02 PM
Accident Prone
Just a n00b's Avatar
It's drag racing; you don't need brakes. Save weight and get a parachute instead
[/sarcasm]
I don't know much about drag racing so I can't offer any real advice.
Old 08-26-2013, 09:10 PM
vivid 02's Avatar
Swap over to a GSR spindle to fit a typical 4 lug 13x8. Then when your done at the track and slicks swap back to your 5 lug spindle.
Old 08-27-2013, 08:59 AM
I said I don't want a title!
Todd00's Avatar
So I take it that you don't have an ITR, but you upgraded a normal 'Teg/hatchcrap to a 5-lug ITR setup?
Or am I missing something?
Old 08-27-2013, 10:04 AM
SF_EF8's Avatar
lol
Old 08-27-2013, 01:18 PM
Accident Prone
He needs the 5 lug to win car shows mang!
Old 08-27-2013, 02:26 PM
kyosoeg6's Avatar
this is a perfect example of a bitter old man. id hate to be around when your R motor blows
Old 08-27-2013, 02:27 PM
kyosoeg6's Avatar
Thanks in advance!
you can buy my 14 in bogarts which are lighter than the 13in lensos
Old 08-27-2013, 02:54 PM
ekcoupeh22's Avatar
I have done it to mine. There are multiple ways of doing this. You can buy the front brake kit from keizen speed and it will clear or you can go the cheap route like me I have gsr knuckles gsr calipers re drilled gsr rotors so they are 5 lug and 5 lug hubs.
Old 08-28-2013, 07:49 AM
Todd00's Avatar
OP is a perfect example of going for the 5-lug bling when what he really needed was a set of good pads with 4-lug brakes because the car was intended to be a drag car all along. No one buys 13x8's with drag tires just for the heck of it.
Nothing bitter old man about building a car correctly rather than putting needless bling parts on it that make your final quest that much more difficult.
Duh.
Old 08-28-2013, 10:00 AM
SF_EF8's Avatar
The drag car in question is a Type R.
Old 08-28-2013, 11:19 AM
Todd00's Avatar
Then there is no "easy" way to do it (aka something done in the parking lot in 15 minutes before/after a drag race). Have to get brakes that'll fit under a 13" wheel, which would be something on the lines of an OEM GSR setup. He'll save weight that way, as well.
Just convert it over or run a 15" drag wheel.
Old 08-28-2013, 11:36 AM
ekcoupeh22's Avatar
Originally Posted by ekcoupeh22
I have done it to mine. There are multiple ways of doing this. You can buy the front brake kit from keizen speed and it will clear or you can go the cheap route like me I have gsr knuckles gsr calipers re drilled gsr rotors do they are 5 lug and 5 lug hubs.
Ill reiterate. 15" wheels are not good for drag racing. It's a trans killer.
Old 08-28-2013, 11:43 AM
FlewByU352's Avatar
My advice would be to sell the OEM 5 lug setup and pick up full 4 lug Integra stuff. You will have at least $400 in your pocket and the car will be lighter.
Old 08-30-2013, 10:01 AM
Daniel_Bunny's Avatar
Duh.
I want to see your ITR.
Old 09-04-2013, 12:40 AM
HotboxedTypeR's Avatar
gsr 4 lug
Old 09-04-2013, 08:32 AM
Accident Prone
shots fired shots fired.
Quick Reply: Anybody know how to get a 13x8 wheel on a ITR 5 lug set up.
