98 crv trailer arm bushing
Old 08-20-2013, 04:01 PM
swordofdoom's Avatar
Default 98 crv trailer arm bushing
Anybody. now what energy suspension trailer arm bushing works for a 98 crv? Mines shot and I'm looking for something that won't require too much work down the road again.
Old 08-20-2013, 04:56 PM
gxr154's Avatar
Default Re: 98 crv trailer arm bushing
wondering if mine were worn out too....does your crv hit hard in the rear when you hit a bump and feel like it swerves the rear???...
qwrty's Avatar
i use this FTW!
http://www.ebay.com/itm/Whiteline-Rear-Trailing-Arm-Bushings-Pivot-Position-Honda-CRV-2WD-1997-4WD-2-/140857491158?pt=Motors_Car_Truck_Parts_Accessories&hash=item20cbc2bed6&vxp=mtr
do it once, do it right!!
good luck!
Old 08-20-2013, 05:26 PM
civiceg94's Avatar
I used civic si from energy suspension
Old 08-20-2013, 06:30 PM
Yeah if there is even a tiny bump u can hear the rear rattle. I looked underneath and both arms were ripped at the top and bottom where the metal bar sits. I just replaced the whole front bushing set so now the noise is clear on where its coming from. The front was way worse with a metal to metal sound.
Old 08-20-2013, 06:35 PM
boliviansol's Avatar
I replaced mine with oem figured if they made it this long they should last me another 13 years
Old 08-20-2013, 07:11 PM
fitseries3's Avatar
+1
way better than OEM replacement. a little stiffer but thats not a bad thing
all 88-00 civic/integra energy suspension RTA bushings are all same and will work in crv just fine.
Old 08-21-2013, 09:26 PM
I bought some energy suspension today since the 88-2000 civic trailing arm bushings will work. These are the ones where you re-use the old sleeve and the metal bar inside.
Old 08-21-2013, 10:01 PM
shermanyang's Avatar
I'm going to try the old silicone filling trick on some new bushings....
Graybeard327
07-16-2017 06:42 AM
705ludeSH
11-15-2013 09:30 AM
tlchkc
11-16-2009 11:19 PM
R00teg
Suspension & Brakes
07-16-2009 02:05 PM
Quick Reply: 98 crv trailer arm bushing
