steering wheel has a wobble and car is pulling to the right
Old 08-12-2013, 01:10 PM
CivicSos's Avatar
Default steering wheel has a wobble and car is pulling to the right
Just like the title says is what the car is doing. Its a 99 Civic Ex Coupe. I know a few things to look out for but im also looking for other things to check if this is common with these cars. First I'll check to see if the wheel weights are on all the wheels, then I'll check the tires to see if there are any steel belts separating causing any bubbles in the tread, then I'll check tire pressure. The tires have excellent tread left so I'm hoping there aren't any problems there. If there are any other things you all can think of for me to check that would be greatly appreciated!!
Old 08-12-2013, 01:30 PM
MyWhiteEJ6's Avatar
Default Re: steering wheel has a wobble and car is pulling to the right
Take it in for an alignment.
Old 08-12-2013, 01:38 PM
B_Swapped93's Avatar
lol^
Check for play in the wheel L to R jack the car up and try and wiggle the wheel. inspect the balljoints and that nothing is loose suspension component wise. check that the axel is seated.
my guess tierod
Old 08-12-2013, 04:27 PM
CivicSos's Avatar
I only jacked up one corner of the car at a time and all tires look fine. I did a viausl inspection of everything and it looked good to me. I did the whole top to bottom shake to check the ball joints. I could turn the wheels side to side pretty far with some with effort. I also checked all the tires for pressure and they were all fine. Took it for a short ride and didn't have much vibration on the little highway I drove on but it still pulled to the right.
Old 08-12-2013, 04:33 PM
CivicSos's Avatar
I also can't keep a smooth rotor on the car. I bought it with a warped rotor thinking "thats an easy fix" After I fixed it 3 months later it was warped again damnit I've just dealt with it for the last 6 months
Old 08-12-2013, 05:03 PM
so uneven brake pad wear causing the rotor to wrap, you must have forgot to grease the sliders
Old 08-12-2013, 05:39 PM
CivicSos's Avatar
That is possible but I usually use grease.
Old 08-13-2013, 03:42 AM
I like the tuna here
DumpdEJ6's Avatar
Uneven tire pressure will cause the car to pull to one side, as well as bad alignment, which you can only eyeball the problem in extreme cases. Your toe is probably out of alignment.
Old 08-25-2013, 09:48 AM
CivicSos's Avatar
I changed the rotors yesterday and there was plenty of grease on the back of the pads. Im thinking I might have a sticking caliper cause sometimes while braking through a turn and letting off the brake the car will sometimes feel like it is still braking. Sometimes during a long braking curve halfway through the brakes will grab more with no more pressure applied. Maybe I ought to change the calipers before I warp these rotors. Pads were fine though.
Old 08-25-2013, 11:18 AM
CivicSos's Avatar
After changing the rotors I still have the wobble in my steering wheel going straight and the car is pulling to the right. Guess I'll save up for some tires and and an alignment
Old 08-25-2013, 11:40 AM
mx73lol's Avatar
Back to the OPs concern......is the steering wheel off center when driving straight? And if it is off center, is it to the left or to the right? Does it pull to the right with the steering wheel straight? Does it only pull when you let go of the steering wheel? Wobble is a tire imbalance. Get them rebalanced.
Old 08-26-2013, 12:28 PM
CivicSos's Avatar
When I drivestraight the steering wheel is straight but as soon as I let go it veers to the right.
FrodeyEJ1
10
10-18-2012 10:15 AM
vtec25
03-04-2008 10:58 PM
h22pwr
04-12-2006 06:46 AM
Veil_Side_
04-09-2002 12:20 PM
Quick Reply: steering wheel has a wobble and car is pulling to the right
