Drop springs
Re: Drop springs
OP, are you planning on getting struts at the same time? With good struts like the Koni yellows, you can run much higher spring rates without blowing the struts. With stock struts, you want the height and spring rate to be as close to stock as possible to keep the struts in good shape.
