Which distributors fit 1991 ED7 D16A9?
Hi there peeps.
Searching the net I can't really figure out which distributor fits my i1.6 DOHC D16A9 engine. As example D16A1 and a others from the D16A* line might be usable. But again this is a DOHC.
I this engine the same as the one called JDM ZC?
Also I've read something about a Acura Integra distributor that fits. Fits meaning: exactly the same / drop in replacement
Also I've found this list: (unfortunately I don't have the url. I copied the list)
It seems to me that I need TD-03. But if some of the others can be used because they're the same, I'd really like to know.
I need to go hunting for a new distributor.
Thanks for the help.
- Victor
- [TD-01] Civic/CRX DPFI 1988-1991
- [TD-02] Civic/CRX MPFI 1988-1991
- [TD-03] OBD0 DOHC ZC Civic/CRX 1988-1991
- [TD-22] OBD0 B16 Civic/CRX/XSi 1988-1991
- [TD-23] OBD0 B18a Integra 1990-1991
- [TD-31] Accord 1990-1991
- [TD-41] Civic D15b Non-VTEC 1992-1995
- [TD-42] d16z6/d15b VTEC 1992-1995
- [TD-43] OBD1 DOHC ZC 1992-1995
- [TD-44] OBD1 B16/GSR/ITR VTEC 1992-1995
- [TD-46] OBD1 b18a/LS/B20/CRV 1992-1995
- [TD-52] Accord 1992-1993
- [TD-55] OBD1 b18a/LS/B20/CRV 1992-1995
- [TD-60] Prelude H22a 1992-1996 JDM
- [TD-63] OBD2 99-00 OBD2 Civic D-Series Non-VTEC
- [TD-68] OBD1 B16/GSR/ITR VTEC 1992-1995
- [TD-73] OBD2 99-00 OBD2 Civic D-Series Non-VTEC
- [TD-84] OBD2 B16/GSR/ITR VTEC 1996-2001
- [TD-89U] Prelude H22a 1997-2001 JDM
- Victor
Re: Which distributors fit 1991 ED7 D16A9?
all of the engines listed above are DOHC, all use the same distributor and only the TD03U distributor fits - no SOHC distributor will fit
I should add that the EDM D16Z5 also uses the same distributor - it is also DOHC, basically the same as the D16A8/A9
freshly boosted DOHC ZC
01-12-2007 11:50 AM
97grnrs
12-10-2006 04:14 PM
