Highway speed front end shake
Old 07-08-2013, 12:27 PM
hatch92civic's Avatar
Default Highway speed front end shake
Just picked up a 90 civic Si with 156k runs great and smooth around town but once I get on the freeway I get a shake in the front end. No shaking in the steering wheel, I feel it in my seat and feet mostly. Starts above 70mph. The more gas I give it or try to speed up the worse the shake gets. Put a set of hx wheels on and still does the same thing. Any ideas?
Old 07-10-2013, 05:15 PM
Default Re: Highway speed front end shake
Had the wheels and tires rebalanced today but problem is still there. No one can help?
Old 07-10-2013, 05:27 PM
F22Master's Avatar
Axles, wheel bearings, brake rotors, it could be anything rotating.
Old 07-10-2013, 05:32 PM
Tyson's Avatar
Check for play in ball joints.
Also take your rotor off and clean the face of the hub. I fond once the rotor was not cleaned off when new and there was a film of the anti rusting oil from when they come new was that was not cleaned off. So it was causing vibrations and warping my rotors too.
Similar to you since the vibration happens after 60 mph when it's typically just a balance issue.
Old 07-10-2013, 06:30 PM
EFlovin''s Avatar
Could be mounts. They get old and the bushings crack.
Old 07-10-2013, 06:43 PM
jpnolan's Avatar
Also could be a bent wheel.
Old 07-11-2013, 05:52 AM
category5's Avatar
Jack the front end up and place it on jackstands, leave the wheels on the car. Then grab a wheel and check for any play from <> like 9 and 3 oclock and also ^V 12 and 6 oclock.
Any play from 12 and 6 is most likely ball joints
Any play from 9 and 3 is most likely tie rod ends (or the rack end bushing if play is only on pass side)
No play, possibly a balance issue.
Play in all directions possibly wheel bearings.
cdmef
12-20-2008 07:17 AM
civic89si666
26
02-07-2008 10:33 AM
R6E6I6D
01-19-2006 12:43 AM
honda94ex
08-14-2005 10:48 PM
Elmojo
14
08-11-2004 03:43 PM
Quick Reply: Highway speed front end shake
