My j series s2000 drag car build
Old 06-27-2013, 10:41 PM
SwappedTURBOegg's Avatar
Default My j series s2000 drag car build
Ive always wanted a s2000 for the only reason to cut it up and build a drag car. i found a shell randomly/locally,so i picked it up. plans are for stock K24 turbo TH400 ford 8.8 27.5x12x15 tires. then dial in chassis and make it faster as time goes on. no class rules just a grudge car/street car
former glory
how i found it,sitting like this for a few years.
home cleaned up
parts of cage i didnt like
wheels
wheels with stock suspension
got to cutting
grinding brakets off so the rearend can be narrowed,this is a nightmare
more cutting test fitting measuring.
not enough clearance for me taking 2" off this side of the explorer 8.8
looking good
front clip acquired was too short gonna need to fab the rest up
found a s366 local for cheap its what im going to run for now.
hoodrat building the accord k24
front end parts acquired aswell as new doors.
more pics will be updated daily,the rear end is in the shop getting narrowed 4 link going in after that.
Old 06-27-2013, 11:31 PM
secondlife2's Avatar
Default Re: My hoodrat DRAG S2k build
sweet i love it. good luck
Old 06-28-2013, 01:01 AM
civic efb16's Avatar
nice good luck with the build
Old 06-28-2013, 03:30 AM
Tuner Eddy's Avatar
Good luck man! Looks fun!
Old 06-28-2013, 04:21 AM
redboost10's Avatar
concrete block???
Old 06-28-2013, 05:34 AM
tuhboek's Avatar
Nice. good luck!
Old 06-28-2013, 11:16 AM
artie89's Avatar
nice
Old 06-28-2013, 11:40 AM
MugenSpeclNY's Avatar
Originally Posted by redboost10
concrete block???
lmao exactly what i thought when i first saw the thread title
Old 06-28-2013, 03:15 PM
spens 91 Ef's Avatar
is that a truck rear end? i see you reference explorer and ford
Old 06-28-2013, 06:03 PM
yes its a ford explorer 8.8 rear end.
not filling this block...
ekcoupeh22's Avatar
Sick! Running An 8.8 I see nice and cheap? I figured a 9" would be better lol
Old 06-28-2013, 06:05 PM
i wanted rear disk, plus the 8.8 is plenty strong and more available.
Old 06-28-2013, 06:09 PM
redboost10's Avatar
More reliable than what? Stock s2k diff?
Looking good
Old 06-28-2013, 06:33 PM
Looking good
plus the 8.8 is plenty strong and more available. is what said about the 9
Old 06-28-2013, 07:16 PM
narfdanarf's Avatar
Reading comprehension ftw
Old 06-28-2013, 07:31 PM
i never said reliable. i said available. for the 3rd time now.
Old 06-28-2013, 07:37 PM
redboost10's Avatar
Sorry. Stupid iPhone has such small print. What gear you going to run?
Old 06-28-2013, 07:55 PM
luck4rmkc's Avatar
In for this! Good luck with the build!
Old 06-28-2013, 08:15 PM
Ron@RLD-Fab's Avatar
Is the rear setup going to be a 4 link or ladder bar? and have you thought about running a powerglide over the th400?
Old 06-28-2013, 09:05 PM
narfdanarf's Avatar
He said hoodrat build...You can get a th400 for $100 and they will take anything a stock block k motor will make.
Old 06-28-2013, 09:39 PM
AR Performance's Avatar
Very nice my is on hold but can't wait
Old 06-28-2013, 09:40 PM
Its a 4 link i have the competition engineering magnum kit. a glide is most likely to be tossed in to the car at some point when its making more power and sees less street duty.
i bought a stock chevy th400 for 40 (witch ill build later)but my dad had a pontiac th400 that was "built" 15 years ago and sitting scene,so ill make a multy adapter plate to run both.
I currently have 410 gears and a factory LSD but will likely buy a 327 off craigslist for 50 bux locally so i can roll race it.
ill push the K24 hard in stock form i don't care if it breaks. but rpm will limit what the trans can take is why the k24 staying stock for now. has a2 cams a2 pump crv pistons crv head.
Old 06-28-2013, 10:44 PM
Bolt pattern on the glide and turbo400 are the same just different input shafts and trans mount location will be slightly different, going with the auto trans is the only way to go IMO, good luck on the build
Old 06-28-2013, 11:07 PM
01typerboi's Avatar
cool build. cant wait to see this build come together
Old 06-29-2013, 05:54 AM
gutted-dx's Avatar
I love watching builds that I could never afford hahaha
Quick Reply: My j series s2000 drag car build
