f22b with trans interfearing with passanger side radious arm
Old 06-22-2013, 07:50 AM
shawn96accord's Avatar
Icon2 f22b with trans interfearing with passanger side radious arm
hi I have a 96 Honda accord with a new f22b engine and trans from h motors in California how ever the accord had a f22b2 as the old motor but the new set up is in the car and running good besides the transmission hits the passanger side radious arm when hitting a little bump need to no how to fix went to junks yards in Louisville ky and didn't find nothing thanks your help will be wonderful.
Old 06-22-2013, 08:09 AM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: f22b with trans interfearing with passanger side radious arm
Did you change from AT to MT?
Old 06-22-2013, 09:53 AM
no the car always was AT so kept it that but it was a 4 speed and got changed to 5speed automatic transmission there is a little black cap on the end of the transmission that the radious bar keeps hitting
Old 06-22-2013, 11:04 AM
MM Gruppe B
MAD_MIKE's Avatar
Radius rod shape changes depending on transmission.
CD MT cars have a round rods on both sides
51352-SV4-003 ROD, R/L FR. RADIUS
CD AT cars have a flat rod to clear the larger AT case.
51352-SV4-961 ROD, R. FR. RADIUS (AT)
You may have to use a radius rod from either a later model 98-02 Accord have a large saddle bend,
51352-S84-A01 ROD, R. FR. RADIUS
or a 92-96 Prelude which has a bend
51352-SS0-003 ROD, R. FR. RADIUS
or 97-01 Prelude
51352-S30-013 ROD, FR. RADIUS
or 95-? Odyssey which had a gear indicator on the right side cover.
51352-SX0-013
...to clear the 5spd AT.
But you will need to verify that the rods are of the same length and have the same two bolt pattern on the arm and where the bushing is mounted.
ChelseaG
Honda Accord (2013 - 2015)
12-08-2017 11:24 AM
MollyXdanger
01-08-2016 08:22 PM
kccord
09-25-2009 04:38 AM
kornerk12
11-16-2008 09:23 AM
Fly1865
02-11-2004 04:28 PM
Quick Reply: f22b with trans interfearing with passanger side radious arm
