96 00 civic window fix? unhappy
Old 06-17-2013, 05:22 AM
sleepyaccord96's Avatar
Default 96 00 civic window fix? unhappy
so i took my drivers side door apart on the 96 hatch and i replaced the glass and all the rubber seals on the whole door... Everything went together perfectly. Well it still does the same thing..when you roll the window UP once it gets 80% of the way close it starts acting stupid again and the back of the glass towards the rear of the car wants to go up and the font wants to stay still which in turn it wants to jump off track.
Whats the secret to owning a 96 00 civic and having fully functional windows?
The only thing i haven't done is grease the tracks..
sleepyaccord96 is offline
Old 06-17-2013, 05:27 AM
Default Re: 96 00 civic window fix? unhappy
i replaced the seals and all door rubbers and glass because PO sealed both door windows shut with clear silicone. to make the car door silicone free i replaced the pass side door as a whole and i changed parts on the d/s
Old 06-17-2013, 07:58 AM
whee-sconsin!'s Avatar
Lube those babies! Silicone spray down the channels every so often will solve it. Honda service tech gave me the heads up and I've never had a problem since.
whee-sconsin! is offline
Old 06-17-2013, 08:04 AM
Joshka89's Avatar
That's a motor/track issue not an issue with glass or seals.
I have no idea how to change the motor since it's behind welded metal
Joshka89 is offline
Old 06-17-2013, 08:19 AM
kyden's Avatar
you probably have a bad regulator. pretty common.
kyden is offline
Old 06-17-2013, 08:24 AM
had to replace seals and glass regardless..someone GLUED/SILICONED the windows close and i was unable to open them due to them having 1"+ thick silicone adhesive all over the glass/rubbers/seals and everything.
im lost as to why the glass wants to act up so bad....i will try and lube the tracks today and try that.
Old 06-17-2013, 10:22 AM
EJ8mike's Avatar
I vote regulator, not too hard to replace, 30 bux advanceauto
EJ8mike is offline
Old 06-17-2013, 11:12 AM
not for a manual window... cant even fine manual window regs anywhere but honda local dealer and i found a elcheapo brand on ebay for 47
Old 06-17-2013, 11:17 AM
http://shop.advanceautoparts.com/web...hedFrom=header
only manual window regs they sell are for 4 door sedan. Not coupe/HB
Old 06-17-2013, 02:52 PM
EJ8mike's Avatar
Ah, was thinkin u had power.....
Did u grease the tracks yet?
EJ8mike is offline
Old 06-17-2013, 10:53 PM
freddy chavez's Avatar
Im having the same problem right now
freddy chavez is offline
Old 06-18-2013, 02:55 AM
I like the tuna here
DumpdEJ6's Avatar
I was having the same problem, loosen all the bolts slightly and you should be able to adjust the two on the far left hand side either up or down. I forget which way I adjusted mine, I *think* it was all the way up. You've probably already tried that, but if you haven't, its worth a shot. That and some lube on the track and mine rolls up perfect.
DumpdEJ6 is offline
Old 06-18-2013, 04:03 AM
silkypillows's Avatar
^This.
The holes are slotted for slack in the door frame. loosen the bolts holding the window frame sliders and (if necessary) regulator. adjusting whichever way is needed - snugging down the bolts and testing window up and down until the frame is holding the window evenly across it's full travel without binding.
you could also try rolling up the window with one side of the frame loose - holding it in different places. if it rolls up nicely, tighten down the frame and try to roll the window down very carefully. If nothing binds, your in a sweet spot. if not re-adjust opposite side and try again.
it can be a process getting it in the correct spot
silkypillows is offline
Old 06-18-2013, 04:47 AM
^^ done it and nothing helps.. the tracks have barely any adjust-ability.. maybe 1/16" at most
have not greased tracks yet, it has been raining like a **** here for 2 days. i think i may make a vid and post it here
Old 06-18-2013, 04:49 AM
alex eg hatch's Avatar
Originally Posted by silkypillows
^This.
Will definatley try this. My window always comes off track..
alex eg hatch is offline
Old 06-18-2013, 05:25 AM
^ there is barely ANY adjustment... i mean i did all of the above and it changed nothing...
If you had an EXTREMEly small amount of adjustment needed it would be ok and would work well but i am off by like 1" so this ain't helping me.
Old 06-18-2013, 05:32 AM
Joshka89's Avatar
Can you give us a picture of where the window stops and then the tracks and how the glass is mounted?
I could help better if I could see what you're working with here.
Joshka89 is offline
Old 06-18-2013, 06:18 AM
gotta pull the door panel back off.. i am gonna also shoot a vid of this BS.
Old 06-18-2013, 06:21 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
had the same thing, bought an OEM regulator from majestic honda and it works fine now.
doctorake is offline
Old 06-18-2013, 07:33 AM
and it was what 110~135 dollars?
Old 06-18-2013, 08:13 AM
doctorake's Avatar
I don't know, go look at the site.
Old 06-18-2013, 08:24 AM
85 on passenger side and 90 on d/s... guess i may end up buying one... god i hate how honda windows have so many probs... money money money
Old 06-18-2013, 08:48 AM
doctorake's Avatar
but OEM is worth the money cause it works.
Old 06-18-2013, 08:58 AM
damn right about that...
have you seen the 48 dollar regs on ebay?! lol i cannot imagine how bad that thing would work.
motorpsycho13
06-06-2013 01:07 PM
sleepyaccord96
16
05-30-2013 12:18 PM
iamthefollower
07-20-2011 08:15 PM
shadow765
09-17-2008 09:47 PM
CRXstress
08-01-2004 01:59 PM
Quick Reply: 96 00 civic window fix? unhappy
