Old 06-09-2013, 12:20 PM   #1
chriscar00
Default 2000 honda accord code p0705
code p0705 came up and i tested all the solenoids and they checked out ok. When the car goes to shift the rpms jump up aprx 300-400 rpm. just seeing if anyone had any ideas thanks
chriscar00 is offline   Reply With Quote
Old 06-09-2013, 12:25 PM   #2
MidasGuy
MidasGuy's Avatar
iTrader Rating: (3)
http://www.facebook.com/photo.php?fbid=178817605502072&set=a.178428672207632.59881.100001215002033&type=3&theater#!/profile.php?id=100001215002033
Default Re: 2000 honda accord code p0705
P0705 Short in Transmission Range Switch Circuit (Multiple Shift-position Input)
MidasGuy is offline   Reply With Quote
Old 08-24-2013, 07:55 PM   #3
dlangford
I have a similar problem with a 99 accord automatic. The check engine light came on as well as the maintenance required light. Several error codes (P0705, P0706, P0420 & P0430). I've seen P0420 before, replaced oxygen sensor at exhaust manifold and it went away. I'm new to the forum and can't seem to find anything about the short in transmission range switch circuit error code. any help would be appreciated.
dlangford is offline   Reply With Quote
Old 08-25-2013, 05:46 AM   #4
Lost Again
Recheck the codes? I see a P1706 and P1706 for the trans range switch
My child arrived just the other day; he came to the world in the usual way
I can explian it to you, I CANNOT understand it for you
Lost Again is offline   Reply With Quote
