Blow off valve or not?
Old 05-20-2013, 05:10 AM
Steeve_Civic's Avatar
Default Blow off valve or not?
My greddy is not on good conditions and would like to change, but my car is only for drag racing now, so do I need one?
Do you use one guys?
Old 05-20-2013, 08:43 AM
Zer0_SpeedWorks's Avatar
Default Re: Blow off valve or not?
Tial Q bov here
Old 05-20-2013, 09:46 AM
vtechjunkie's Avatar
^ Same for me. Even though its a race car, I'd rather not have the compressor surge.
Old 05-20-2013, 10:21 AM
Tial Q, seems to be one of the best Blow Valve
Are you using Full throttle shift?
Old 05-20-2013, 10:22 AM
Turbo-LS's Avatar
If you are boosted you should be running a BOV. Its bad for the turbo not to run one. Im running Turbosmart Raceport. Love turbosmart products. tial is good too
Old 05-20-2013, 10:52 AM
Dark_Teg's Avatar
Some people say if you run an anti-surge housing you dont need one. I have the anti-surge housing but went ahead and ran one anyways (Turbosmart Raceport)
Old 05-20-2013, 11:31 AM
99V-unit's Avatar
Yes, you should run one.
I have a synapseengineering synchronic bov and no issues almost 2.5 years later. Its fully adjustable based on how fast you want it to dump.
Old 05-20-2013, 10:03 PM
Divers's Avatar
That is not the same surge. Ported housing are meant to shift a turbo's surgeline to the left by exposing air to the middle of the compessor.
When you slam the throttle shut on a turbo at full speed it will definitely blow all that air out the front of the compressor in a violent way. Run a bov unless you have a diesel
Old 05-21-2013, 11:00 AM
92_DB2's Avatar
Synapse here also. Best BOV on the market.
Old 07-12-2014, 10:20 AM
Which spring is in your Tial or Blow off valve please are you running?
Old 07-12-2014, 11:12 AM
boostjunkie757's Avatar
it would be a good idea to get one if you let off the gas between shifts..
Old 07-12-2014, 12:32 PM
rootbeerbrown's Avatar
I run a tial blow off valve my ef is set up for drag racing as well but if you take off your blow off valve you are just asking for boost leaks the pressure is going to have to go some where when you let off the gas
Old 07-12-2014, 01:34 PM
No more than 12PSI spring?
Old 07-12-2014, 03:41 PM
itspools's Avatar
Tial springs are rated off vacuum so if you pull 20" vacuum at idle run a 10psi spring, 16" run a 8 etc
Old 07-12-2014, 05:41 PM
SPOOLINmatt's Avatar
just run one.
Old 07-13-2014, 02:43 AM
So don t understand, what do you mean please!
Old 07-13-2014, 10:52 AM
Tippyman's Avatar
It explains it in the instructions that come with the valve. Basically if you have a big cam you pull less vacuum so you need a diff spring. A normal engine will make about 20 in hg at idle. Mine makes around 14-15 in hg due to the cam.
Old 07-14-2014, 12:29 AM
Okay, running S2Pro1s cams.
Didn't take attention about that, what are the consequences If spring is too soft or stiff?
Old 07-14-2014, 09:52 AM
scmil95eg's Avatar
If the spring tension is too low, idle vacuum will pull it open when you don't want/need it open.
If the spring tension is too high, vacuum won't pull it open when you do want/need it to open.
Old 07-20-2014, 06:48 AM
Thank you, with map sensor (not maf) we don t matter If it is open at idle, right?
Old 07-25-2014, 11:51 PM
I think it doesn t matter for our Drag car?
Old 07-26-2014, 01:19 AM
Boosted_01 R's Avatar
Using TIAL also, and yes it matters, so you should run one regardless of setup, street or track only, it's doesn't matter if you want to save your turbo.......... Don't think this is an official chart, but basically what everyone is talking about...
Old 07-26-2014, 05:43 AM
phaphon's Avatar
So a stock motor ls b18b1 turbo should need a 11psi spring?cause the one I ordered from go auto works is coming with a 6 psi spring and there was no option to choose from
Old 07-26-2014, 09:07 AM
Just tested at idle, 15.5in/hg, so I need a 8 spring If I want to open the BOV when shifting?
Old 07-28-2014, 05:10 PM
I would go with a 9psi in that case.... I would verify with Tial... just in case the springs have changed over the years....
Quick Reply: Blow off valve or not?
