oil leak form head gasket
Old 05-18-2013, 02:39 AM
2kdrift's Avatar
Default oil leak form head gasket
Have a small oil leak coming from the oil drain in the head leaks out the headgasket near distributor. Dont wanna replace the gasket just yet as its brand new. If it was real bad i would install my built GSR block, not worth the time to pull the head on this block. Ive had this problem with other blocks and deiff heads seems to happen alot (usin arp headbolts if thats any factor) any idea on a quick/temp fix for this issue? again its not a bad leak but some oil does seep out below exhaust manifold runner #4
Old 05-18-2013, 05:00 AM
The Grumpiest
grumblemarc's Avatar
Default Re: oil leak form head gasket
Doubtful it is from the gasket. Probably the distributor O-ring needs replacing.
Old 05-18-2013, 12:00 PM
2kdrift's Avatar
i can re-check but what i did was clean everything off and after oil appeared in the gasket are a it was completely dry near the dizzy and vtec solenoid and cam seal
mijos
09-05-2020 05:56 PM
93grayeg
09-24-2018 03:46 PM
92_Integra_GSR
02-12-2010 05:13 PM
Bradsxx7
05-30-2009 10:33 PM
brandonEM1
04-10-2009 05:01 AM
Quick Reply: oil leak form head gasket
