Lighting HID/Xenon kits, Retrofits and Associated Topics
Right turn signal flasher/fast blink
Old 05-08-2013, 04:54 PM
greeen ranger's Avatar
Default Right turn signal flasher/fast blink
Got an all natural 99 civic DX. All my turning signals work EXCEPT the right head light one. I've read the repair book but it only refers me to an unclear diagram of the electrical fuses under the dash. The right blinker in the dash blinks faster than normal and the right rear turn signal also blinks faster than normal. Wires look in good shape and I just replaced the front turn signal on passenger side(which is the one that won't blink for anything not even when hazard lights are on) only option I have left to do is check the fuse/fuses for the right turning signal.
Need someone to tell me exactly where this fuse is to replace ASAP
Old 05-11-2013, 08:31 PM
acmoc's Avatar
Default Re: Right turn signal flasher/fast blink
sometimes it's a bulb about to go out
if you can't find the fuse pull them all out and see which are good
MAKE SURE you put the correct amperage fuse in each respective place
Old 05-17-2013, 10:57 PM
ron1's Avatar
may be a faulty bulb socket
Old 06-30-2013, 01:52 AM
Outrun's Avatar
Replace that right front bulb.
Old 08-20-2013, 08:44 PM
lxdriver's Avatar
I had this same problem a while back, fixed it by replacing the faulty bulb and socket with new ones and BOOM!!!
Alonso Robles
06-14-2017 09:14 AM
EM2_PLo
Honda Civic (2001 - 2005)
07-19-2010 12:54 PM
barnie
09-07-2009 07:45 PM
CWBETB
12-04-2006 03:10 PM
O16581724 5 2 5
10-06-2005 10:03 PM
Quick Reply: Right turn signal flasher/fast blink
