rpm jumping
Old 05-08-2013, 06:43 AM
hawker98's Avatar
Default rpm jumping
Hi I have a 95 integra ls with gsr motor and trans. When im cruising or idling or well doing pretty much anything my rpm gauge will tweak out jumping past redline the jumping to 0 rpms or any were inbetween the engine will either lose all power and die or start missing and back firing. Anyone have any ideas what may cause thos even the old ls motor did this I dont think the swap did it. Thnx for your help
Old 05-08-2013, 07:32 AM
SolScifen's Avatar
Default Re: rpm jumping
I'm pretty sure that means your icm/ignitor in the distributor is no good.
Old 05-08-2013, 04:45 PM
hawker98's Avatar
Ok replaced icm everything is fine on short runs but still does it in vtec
Old 05-08-2013, 05:18 PM
fcm
Old Fart
fcm's Avatar
Check the connections to the ICM and coil, make sure they are all tight, you may have to "crimp" the "quick release" terminals a lettle to tighten them up. 94
Old 05-13-2013, 10:01 PM
hawker98's Avatar
Found problem it was lose ground on thermostat housing thnx srry for late update
Naazel Sirez
09-27-2018 03:17 AM
Built4Battle
08-10-2010 05:01 PM
dansred2000si
02-19-2008 05:24 AM
B18c1EKCpe
03-11-2003 09:38 PM
Quick Reply: rpm jumping
