EK Headlight harness wiring gurus needed...
Can anybody please help me locate the connector number for this connector...
It is a connector for the headlight harness on my 97 ek hatch, and I am having a difficult
time trying to locate a wiring diagram online where it displays the actual number for that specific connector. The reason I'm asking is because I took off the stock factory loom that was around that whole headlight harness only only to run into 4 wires that were cut off in the middle of the harness. Those 4 wires go into a gray plug in which plugs into the rest of the harness leading into the dash, and my fuse box. I just want to figure out where these wires go?
I figured out one of the wires. The blue/red wire is for the ac clutch driver inside the pcm itself. The other ones go into the fuse box.
For the brown connector going into the fuse box with 5 pinouts, I noticed the 2 thick wires(red, and white) go into this connector. Then I get completely lost as to what their purpose is.
The other one is a blue & white wire that goes into a gray plug with 8 pinouts, which is also connected to the back of the fuse box. Here are the pics.
Old Fart
Re: EK Headlight harness wiring gurus needed...
OK, first off if it is not a right hand drive, it is not an EK, [EK is a JDM designation].
And are you talking about the under dash fuse box or the engine bay fuse box, hard to tell from the pix.
Let me know the MM&Y of car and >>>trim level<<<, and I will look it up on Mitchal at the shop in the morning. 94
JDM_SOHC
02-11-2009 01:47 AM
AWD: Jeff
08-13-2007 10:14 AM
usdm.ehtu
03-17-2007 07:54 PM
