Was installing my toe arm and this happened...
http://mansion63tsx.acurazine.com/fo...d.php?t=886902
I have an acura tsx 2012 lowered. I was installing my toe arm and the bolt cracked. Now I don't know what I can do anymore. What the shop will have to do to fix this..
Re: Was installing my toe arm and this happened...
Yeah man. Sucks. I'm going to bring it to the mech shop tomorrow to see what they gonna do. I hope it's not too much....
If that bolt screws out of the knuckle you should be able to get some vice grips on it and get it out of the knuckle. Then you could screw another one in. If I understand how it goes together, now that the head of the bolt is broken off there is literally nothing holding it in. It should come out very easily, even if it is badly stretched (which it probably is...).
In the future make sure you check a manual for torque specs. I'm guessing that 45 ft-lbs is sufficient for that bolt.
Wells yeah. The head of the bolt is broken off with a nut on if. So basically the head of the bolt is the picture shown. I just hope the shop don't try to rip me off saying more than what needed to do.
It broke off right there. That's where the toe arm go on then a nut after that. But when I was tightening it. It broke.
Yeah a vice grip still should get the job done (albeit with more force since it's a stud and not a bolt). Assuming also the stud is screwed in rather than pressed in.
Either way it's a trivial problem for a shop to solve and I would not pay more than $5-10 for labor and a similar amount for the part.
Went to my mechanic shop today. He told me to bring it by his house because he can fix it at his house for cheaper. He always does this for all of my cars. He has a little garage where he works on customers cars for cheaper than the shop would charge lol. But anyways, he said that bolt should be able to come out. Just gotta take out the nuts and bolt for the other part. Then this bolt should jam out. But it doesn't look like it can come out that easily. But I don't know, ima have to bring it to his house later
tazeat
Suspension & Brakes
05-23-2010 06:01 PM
