ls obd2 swap in eg hatch
Hey guys so I'm in a pickle lol I recently swapped out the tired d15 out of my hatch and I picked up an Ls swapped everything in but it tries to start but just doesn't things I've done as of last night
Compression check
Checked for spark replaced ecu,fuses, main relay
I can't really figure it out any help guys?
Compression check
Re: ls obd2 swap in eg hatch
Also swapped the obd2 wire harness out but I'm more than possitive it works because my buddy is running a 00 gsr wire harness on his hatch runs just fine
all you have to do is use a obd1 ls distributor and your FACTORY harness. you will not plug in the crank position sensor on the oil pump tho.
and a obd1 ecu.
and a obd1 ecu.
That's what I did went out bought an obd1 p75 and I'm using the Ls wire harness as many people have said they are comparable with the Eg strut tower plugs . Everything is plugged in just won't start
http://technet.ff-squad.com/hybrid.92-95.obd2.htm
Made sure of it looked it up before I even put the swap in
Checked all grounds cleaned the mating surface fuel pump I do hear somewhat a faint prime . I got spark ,I can't really tell what color since I'm out in pure daylight and can't see what color it could be
well the distributor still needs to be wired to obd1 i believe. personally i would have just used the original eg harness and a obd1 distributor. (Guranteed to work that way)
Well I know that as long as I can use the obd2 harness I can use the alternator and distributor .
As of 10min ago I can't hear the fuel pump prime anymore
pipojdm
09-13-2008 01:09 AM
