1997 accord A/C problems
Old 04-27-2013, 10:50 AM
joshiebdapimp's Avatar
Default 1997 accord A/C problems
my A/C clutch does not click in when i turn the a/c button on in the car. i have a test light so i checked for power/ground at the a/c compressor, which in this case is the ground side, and i got nothing at all at the a/c clutch connector. So i checked the relay and i got power coming into the relay and coming out, but no ground coming out of the relay to the a/c clutch which grounds itself on the housing... i switched the relay and still nothing, also my condensor fan doesn't come on either when i turn the a/c on. I know the a/c compressor works and the condensor fan works because i hot wired both of them to see if they worked at all and they both do. What should I do next? Should i replace the A/C pressure switch because it's telling the PCM there's too low of a charge in the system or what? If you've had the problem before and fixed it just let me know!! thx!
Old 04-27-2013, 11:07 AM
92 civic ex 4dr's Avatar
You probably have a leak. The ac system is a sealed system. If it runs out of refrigerant then it leaked out. The ac system doesn't "run out" of refrigerant like some say. If you remove the pressure switch you are going to release any pressure left in the system and introduce air into the system.
At that point you will have to have the system evacuated and properly re charged and oiled to properly cool and run.
Posted from Honda-tech.com App for Android
Old 04-27-2013, 02:32 PM
holmesnmanny's Avatar
Default Re: 1997 accord A/C problems
the ac switch will provide continuity across the pins if there is enough pressure in the system and not too much...if you don't get continuity then you either have too much or not enough refrigerant....normally this is not enough
if you get continuity then you need to get a set of manifold gauges and take some readings..if you don't then you need to add refrigerant and leak detector and check for leaks as well as for readings
Old 04-29-2013, 06:51 PM
i'm sorry guys i forgot to mention that it WAS low on refrigirant when i bought the car which was like two weeks ago, but i recovered what refrigirant that was in it and put a vacumm on the system and then charged it up and still the a/c clutch is not coming on
alextech
Honda Civic (2006 - 2015)
03-27-2018 10:30 PM
BSDMotorSports
07-28-2013 04:12 PM
Mackln308
07-30-2010 11:34 AM
freestyler_
32
07-03-2009 09:23 AM
sk8er602
05-22-2007 07:25 PM
Quick Reply: 1997 accord A/C problems
