head gasket?
head gasket?
Just wanted to be sure, bought a crv with a b20z1 cheap and I did a leak down test, pressurized cyl #4 and the air is coming out of cyl #3. Also, cyl 4 compression is 30 psi. All other cylinders are 180-200 compression. I am thinking head gasket,. Just wanted your guys opinion.
Re: head gasket?
Pour a teaspoon of oil into that low cylinder, and let the rings seal a bit.
Recheck your compression right after on that same cylinder, and see if there is a change.
If there is a change, it's most likely your rings are shot.
Re: head gasket?
that would explain low compression, but how would the air be getting into the neighboring cyl? i ask because i am having the same problem with my gsr, but its cyl 2 leaking to cyl 1. my compression is 180 except cyl2 which is more like 135
Re: head gasket?
If you have access to a smog machine it's easier to check headgasket that way. Really simple, just put probe above recovery tank and rev the motor or snap throttle it. If the HC reading on the machine elevates you have urself a headgasket issue or crack head/cylinder.
Boostn B20
11
11-27-2008 01:22 PM
MrMug3n
07-11-2008 07:13 PM
bleebdat
10-08-2002 03:52 AM
