Old 04-05-2013, 07:47 PM   #1
ef8-dc2619
2000 Acura Integra
ef8-dc2619's Avatar
JDMchipotle
Default Performance Aluminum Radiator or OEM replacement?
So my oem DC radiator with 130,XXX miles is now leaking from the tank where it meets the top. Its time to upgrade right, so I need some feedback to see what works for me. Its my DD and moderately beat upon, mostly babied.
I need something thats direct fit and wont interfere with any oem fans or ac stuff.
leaning towards:
skunk2 alpha
mishimoto
Help
how do you know when its half?
ef8-dc2619 is offline   Reply With Quote
Old 04-05-2013, 07:54 PM   #2
racebum
2002 Chevrolet Corvette
racebum's Avatar
Racebum
Send a message via AIM to racebum Send a message via Yahoo to racebum
Default Re: Performance Aluminum Radiator or OEM replacement?
the best of the breed is the koyo. it uses real brazed tubing and holds up to track abuse
that said i would get another plastic tank from rock auto. the full size integra radiator from the factory is actually quite large for the displacement of the engine.
the stock fans won't fit any of the aluminum radiators except the koyo and that radiator is so thick you can't use stock fans and a header. then again it's so thick you don't even need fans. i kid you not i had one of those on the type r and in 100deg weather. in traffic....no fans, it did not overheat.
you can either get a spectra via rock auto or amazon or the koyo OE plastic radiator is part number W0133-1608401
the big aluminum one is on ebay for $300
something like this is cheap and gets you back on the road
Spectra Premium CU1741 Complete Radiator for Honda Integra : Amazon.com : Automotive Spectra Premium CU1741 Complete Radiator for Honda Integra : Amazon.com : Automotive
Mountain View Carpet Cleaning also found at carpet cleaning beaverton Do you own a turbo honda? see turboinstall.net
racebum is offline   Reply With Quote
Old 04-06-2013, 07:17 AM   #3
drmix
drmix's Avatar
Ive only heard good things about the Mishimoto and is what I plan on buying for my car next. Its got a lifetime warranty as well. The only thing that sucks is you will have to replace the fans to work with this radiator.
09 Ruckus
96 Integra GSR Turbo Build
drmix is offline   Reply With Quote
Old 04-06-2013, 07:35 AM   #4
fcm
Old Fart
fcm's Avatar
Mizu rads from sparkplugs.com...
http://www.sparkplugs.com/Automotive-l134.aspx
http://www.mymizu.com/acuraradiators.html
Works great in my 94 RS, good drop in fit, well made rad, direct fit OEM rad fan, and great service from sparkplugs.com 94
RIP Zack 2001-2013, my best friend.
fcm is offline   Reply With Quote
Old 04-08-2013, 06:05 AM   #5
S2BumpsticksGSR
1995 Acura Integra
S2BumpsticksGSR's Avatar
If you get alum, buy an anode for drainplug- it will keep corrosion(scaling) from building up inside system
3" exh on D16! Sounds tuff bruh! Hehehe
S2BumpsticksGSR is offline   Reply With Quote
Old 04-13-2013, 10:16 AM   #6
ef8-dc2619
2000 Acura Integra
ef8-dc2619's Avatar
JDMchipotle
so I ruled out any alluminum radiator due to header and fan fitment because I dont have the money for slim fans atm. So now I want a koyo radiator either oem replacement or S series the deal now is I cant find one that says showa replacement, all I see is denso only
Old 05-08-2013, 06:11 PM   #7
gomer124
gomer124's Avatar
Send a message via AIM to gomer124
Has anybody actually bought the cheap 30.00 radiators off ebay?? I wreck my hatch every 3 months and am going broke lol, so I'm switching to the ebay radiators....any suggestions or warnings?
"Worrying is like a rocking chair, it gives you something to do, but gets you nowhere."
gomer124 is offline   Reply With Quote
Old 05-09-2013, 01:58 AM   #8
drmix
drmix's Avatar
More of a reason to go with Mishimoto. The lifetime warranty covers accidents.
http://www.mishimoto.com/warranty-info.html
09 Ruckus
Old 05-09-2013, 05:42 AM   #9
HondaPartsHero
Technical Hero
HondaPartsHero's Avatar
I've used both eBay cheapos and recently because of time used a cheapo from advance auto for 75 with a coupon. No difference in quality. I've actually been surprised at the quality of eBay rads and have used about 6 with no issues.
OBD1/2 SOHC/DOHC VTEC HARNESS
MINI ME SUBHARNESS
02 EXTENSION HARNESS
Hondapartshero.net
HondaPartsHero is offline   Reply With Quote
Old 05-09-2013, 05:59 PM   #10
nikesb4dub
nikesb4dub's Avatar
I have the koyo aluminum rad.. v-core 36mm
OEM fitment, drop in. Oem fans fit, etc. I also have a after market header which still has a lot of clearance.
id recommend it
nikesb4dub is offline   Reply With Quote
Similar Threads
96 DC4 build (VERY SLOWWW BUILDDD) 96Black Appearance Build Threads 13 09-11-2013 08:59 AM
CRX oem radiator ATF cooler fittings ??? 99teggsr Honda CRX / EF Civic (1988-1991) 5 07-30-2013 04:10 AM
5th gen radiator in 6th gen coupe? bairdandrew77 Honda Accord (1990 - 2002) 0 12-15-2012 01:57 AM
Experience with BWR BLACK SERIES 1/2 size radiator skateboard_ej8 Forced Induction 1 11-19-2012 02:18 PM
