Instrument panel freak out
Old 03-28-2013, 12:27 AM
brizee's Avatar
Icon2 Instrument panel freak out
I own a 2002 V-6 Accord LX sedan. We experienced a wet snow and freezing conditions last week. After driving the car I noticed that the tach, gas, temp and speedometer do not work at all. Odometer/tripmeter, signal lights, check engine light, tun signals all flash whether the car is moving or not. I tried to reset Maintenance Require light without success.
Key fob works and car will chime for about two seconds when you first open the door and then stops. Lately the car has been left outside where previously it was kept in the garage.
Last activity with car was an emission check on March 5 and everything passed. Car starts and drives fine.
Car has 191,000 miles and recently had major expenditures on timing belt, rotors/pads, engine mounts, power sterring pump and air sensor.
The car has had LED bulbs in the large instrument backlights for about three months.
Any ideas or recommendations would be greatly appreciated
Old 03-28-2013, 06:42 AM
NvBiker1's Avatar
Default Re: Instrument panel freak out
Might check grounds & battery connections
moisture is not good on electronics & grounds
rahulmunjal
02-25-2012 10:42 PM
jay2415
04-08-2010 06:48 AM
EK 2 9K
09-02-2007 05:40 AM
zak88lx
06-05-2007 01:33 PM
alanz
07-18-2006 10:16 AM
Quick Reply: Instrument panel freak out
