PLEASE HELP!! Cant find an answer to this!
Old 03-27-2013, 09:35 AM
Ray99Si's Avatar
Default PLEASE HELP!! Cant find an answer to this!
I have a 99 Si with a GSR swap. My issue is that the car will not shut off when I use the OBD1 ECUs (P28, P72) with conversion harness, but as soon as I plug the stock Si ECU OBD2 (P2T) it shuts off just normally. I have used a few ECUs and have exchanged the conversion harness also and still does the same, only shuts off with the P2T. So, of course I want to use the OBD1 ECUs but cant figure out how to make the car shut off besides stalling it.... Could someone please give me some insight on what to check or do so I can use the OBD1 ECUs and be able to turn off the engine? Thanks
Old 03-27-2013, 09:51 AM
B_Swapped93's Avatar
Default Re: PLEASE HELP!! Cant find an answer to this!
Try a different obd1 ecu (i know you've done this a fiew times but still). like a known good virgin p72 maybe a different jumper harness also
Old 03-27-2013, 12:56 PM
Ray99Si's Avatar
Thanks for the reply. I have tried that already, good virgin P72 and a couple of different harness but still the same result. Only the P2T shuts it off...
Old 03-27-2013, 07:06 PM
crazyhouse2011's Avatar
A good way to shut off your car if it doesn't wanna cut out is to unplug the alternator and disconnect the battery, in that order. It should die pretty quick. Or if you wanna be rowdy, just drop the clutch while in gear and let it stall out.
Old 06-07-2013, 09:09 PM
Ray99Si's Avatar
Bump!
I am still having the same problem, is there anyone here that has any other ideas and/or any input on this? Thanks
Old 06-07-2013, 09:11 PM
n/a2boost's Avatar
Maybe a bad ignition switch.
Old 06-10-2013, 09:34 AM
Ray99Si's Avatar
Thanks, I'll try the ignition switch and see if it works.
Old 07-28-2013, 10:55 AM
Ray99Si's Avatar
So I changed the ignition switch with a new one hoping that it would fix the issue but had no luck, still doing the same thing (Only turns off with the P2T)... I would just leave the stock P2T but you can tell the engine doesnt run right. I would be good with a virgin P72 but I have tried a couple of them (OBD1 and 2) and still the car wont shut off... I know how to turn it off but of course I want it fixed. If anyone knows what else to check please let me know.
jdmshawn95
01-14-2011 11:12 AM
vlc92189
10
01-29-2010 10:50 AM
spool310
09-06-2006 10:02 AM
stehigs321
02-21-2004 04:07 PM
stehigs321
02-21-2004 12:03 PM
Quick Reply: PLEASE HELP!! Cant find an answer to this!
