Southern California Fresno & Below
IACV issue
Old 03-25-2013, 03:31 PM
Daz-E's Avatar
Default IACV issue
I have a 97 hatch with a "Mini-Me" swap in it that I need to smog(Star smog). I bought the car this way and its been really reliable so far(I had it for a year now). I need to smog this car and I thought by putting the stock pcm back in it would be fine. Apparently the p28 that is in is tuned to make it run cause when I put the stock pcm in I have a Cel for IACV circuit. I did a little digging and found that it was a 3 wire made to a 2 wire IACV. So the orange signal wire is not even attached to anything.
The p28 has an adapter harness that it plugs into to work but I guess it is not hooked up to OBDII port.
Is there a way around this ?
Old 03-26-2013, 08:53 PM
Daz-E's Avatar
Default Re: IACV issue
Anyone ???
Old 04-01-2013, 06:42 PM
HEADS OR TAILS's Avatar
wat obd2 ecu are you using. you need the d16y8 ecu they use the 2 wireiacv
Old 04-02-2013, 08:33 PM
Daz-E's Avatar
P2e !
Old 04-03-2013, 07:47 AM
the P2E is the d16y7 ecu and it uses a 3 wire iacv. you need a P2P, that's the ex ecu that runs the 2 wire iacv
Old 04-05-2013, 12:08 PM
Daz-E's Avatar
Will that ecu plug into my d16y7 harness ?
Old 04-05-2013, 06:55 PM
yea It will plug into your harness, you might need a knock sensor and vtec needs to be wired
Old 04-06-2013, 01:09 PM
Daz-E's Avatar
I would have to wire vtec to that ecu ? If I brought my car to you could you do this for me(I would obviusly pay) ? How long would it take ? How much are the parts ?
Old 04-06-2013, 04:26 PM
Well is vtec already wired. vtec and knock would take less then a hour to run and hookup. email me
Old 04-07-2013, 11:31 AM
Daz-E's Avatar
Yes Vtec is already wired in and its running on a p28 ecu. It runs good with no problems and I get great mpg(37-41mpg hwy).
Old 04-07-2013, 07:45 PM
ok then we just need to wire the knock sensor. email me headsortailsmotors@gmail.com
Old 04-07-2013, 10:30 PM
Daz-E's Avatar
Email sent ! Titled "Knock Sensor Wiring" !
Old 04-22-2013, 07:07 PM
Daz-E's Avatar
Ok ! I purchased the p2p, knock sensor, and installed a new used Cat. Just need to wire up the knock sensor and potentiometer(for the fuel pressure sensor). I should be ready for smog in a day or 2.
Daz-E
10
03-29-2013 03:57 AM
bcumbie
Engine Management and Tuning
03-16-2012 08:49 PM
Arseezy
08-18-2011 05:16 PM
IDriveHonda
04-13-2008 06:13 PM
igo4bmx
05-28-2004 03:26 AM
Quick Reply: IACV issue
