Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 03-25-2013, 10:04 AM   #1
Key Enzyme
1993 Honda Del Sol
St0n3d ra1d3rx3
Default Is wastegate suppose to be open at idle?
I just noticed that my wastegate is slightly open at idle enough to feel exhaust gas coming out. I took it apart but nothing looks out of place, its a tial knockoff from dna motoring. There is a nut inside that i loosened so the valve could close but it still opens up with a little pressure. Im thinking it was just made wrong? I think its causing me to lose power and making me spool late. Also theres a guy selling a tial WG on craigslist for 150 should i go for it or try to fix mines?
Key Enzyme is offline   Reply With Quote
Old 03-25-2013, 10:58 AM   #2
Muckman
Moderator
Muckman's Avatar
iTrader Rating: (2)
ccmuckman
Send a message via ICQ to Muckman Send a message via AIM to Muckman
Default Re: Is wastegate suppose to be open at idle?
No.
Make sure you have the fire ring installed and the boost reference hose is connected to the side port and the top port is vented if not using an EBC.
Integra GSR 13.5:1 GT30R 597hp build
Evo9 MR SE
Muckman is offline   Reply With Quote
Old 03-25-2013, 12:45 PM   #3
Key Enzyme
1993 Honda Del Sol
St0n3d ra1d3rx3
fire ring is installed correctly. When i tap the thottle slightly it closes up . WG is working fine too. Side port is going to vacuum manifold . Top port is going to my MBC. I was just curious because i thought i might be losing power because of it.
Old 03-25-2013, 02:16 PM   #4
Muckman
Moderator
Muckman's Avatar
iTrader Rating: (2)
ccmuckman
Are you talking about a wastegate open at idle or the blow off valve?
Old 03-25-2013, 02:55 PM   #5
Gunmetal_B20_Hatch
1992 Honda Civic
Gunmetal_B20_Hatch's Avatar
iTrader Rating: (8)
Had this same issue with a knock-off gate. Get a name-brand one. PTE preferably.
Originally Posted by Tyme2Breathe View Post
No tune. Turbo was was installed about three weeks ago. It ran fine up until Mon.
1992 DX Hatch - Fully built 2.0L non-VTEC - 7.68 @ 95 (only 12psi)
Gunmetal_B20_Hatch is offline   Reply With Quote
Old 03-25-2013, 05:55 PM   #6
SiRCiviC94
I heard the blow off can be open at idle.
Wastegate. Tial n forget about it
98 ek stock gsr - ???
Originally Posted by creation25 View Post
Yes that! when going on roads the car keeps skirting like that with a 'sssssssss' noise.
SiRCiviC94 is offline   Reply With Quote
Old 03-25-2013, 07:10 PM   #7
Key Enzyme
1993 Honda Del Sol
St0n3d ra1d3rx3
muckman i was talking about the Wastegate. I ended up getting the tial for 130 which i think is a great price. I noticed a lot of differences BIG time! Fully closed at idle. No ,more exhaust gas leak sound. Also spooling much sooner and sounds better!
All thats good now but now i have another problem =[
I have a slight fluctuating idle from 1000rpm to 1200. I checked for vacuum leaks and couldnt find any. I got my car tuned 2 days ago and prior to getting it tuned it was fine on the basemap. Think my tuner did something wrong?
Old 03-27-2013, 12:33 AM   #8
Hand_Fed
Hand_Fed's Avatar
I'll chime and would have to say if it's open that's a big no no and you have a problem
"My number one policy is quality. Never sell my soul is my philosophy.
High velocity, lyrics like Nostradamus making prophecy
I told you cats a long time ago there ain't no stopping me!"
Hand_Fed is offline   Reply With Quote
Old 03-27-2013, 01:31 PM   #9
Key Enzyme
1993 Honda Del Sol
St0n3d ra1d3rx3
Thats what happens with ebay junk i guess. Swapped it for a Tial and fixed everything
