QUESTION ABOUT MY CLUSTER CIVIC SI
Re: QUESTION ABOUT MY CLUSTER CIVIC SI
it is neither mph or kms. That is the trip meter, which on your cluster is in miles, as mph are the bigger, more predominant numbers on your speedometer and kms are the smaller printed numbers.
R u in the states or in DR? Im scared of all Dominican cars, I had a couple cars out there (including an ek with a b16a2) and all of them were hacked half way to ****.
Either way, check to see if ur cel works. turn the ignition on but not the motor. All the lights in the dash (including the cel) should light up. If it doesnt light up, el tiguere k t vendio esa vaina t akaba d enganiar. lol
Ugh. Will somebody PLEASE EXPLAIN TO ME WHY PEOPLE PUT EYELIDS ON THEIR HEADLIGHTS? What is the point? Are you not happy with the shape of your OEM headlights? It just looks bad. If you wanted to modify the quarterpanel so it extends over the headlight, that would look better, but it is plainly obvious that there is a black piece of plastic over your headlight. Doesn't that affect visibility too?
HondaGuy221
Honda Civic (2006 - 2015)
03-09-2015 06:44 AM
