question about intercooler pressure drop
Old 10-22-2002, 06:11 AM
Mr. Softee's Avatar
Default question about intercooler pressure drop
why does pressure drop occur? Is it becuase of air's temperature drop leading to pressure drop in accordance with Amonton's laws? Or is it from something else? I would asume pressure drop is good, as it is impossible for air to become cooler without loss of pressure(asuming volume and incoming pressure are constant)- correct?
Old 10-22-2002, 07:33 AM
94turboteg2's Avatar
Default Re: question about intercooler pressure drop (94goldjungsr)
I read somewhere it was because of "aerodynamic drag".
The key is as long as the density charge gain is greater than the power loss (due to pressure drop) the intercooler is ok.
Old 10-22-2002, 08:27 AM
bmm89's Avatar
Default Re: question about intercooler pressure drop (94turboteg2)
They had a real good series of articles on the autospeed site(crazy aussies) in which they measured the plumbing pressure drops and fixed them... http://autospeed.com/index.html
Old 10-22-2002, 09:19 AM
mos
mos's Avatar
Default Re: question about intercooler pressure drop (bmm89)
direct link:
http://www.autospeed.com/A_0652/page1.html
err try this one.
http://www.autospeed.com/A_0754/page...rc=suggestions
[Modified by mos, 10:25 AM 10/22/2002]
Old 10-25-2002, 08:25 AM
craesq's Avatar
The pressure drops because the temperature drops. Colder air is more dense (i.e. you can fit more atoms in the same space). I was running 7psi without an intercooler and it dropped to 5psi when I put the intercooler on.
Old 10-25-2002, 10:50 AM
Prod's Avatar
Simple, pressure drop occurs due to airflow restriction
Airflow can be restricted by tight bends in pipes, inadequate pipe sizing, obstructions in air path etc...In an intercooler the main thing that is going to cause pressure drop is turbulator density. If you have very dense turbulators then the air will remain in the IC longer and you will likely see more efficiency, however at the expense of pressure drop. Vice versa as well...The other thing with IC's that can cause a nasty pressure drop is bad end tank design and of course leaks.
Old 10-25-2002, 01:07 PM
niedejb's Avatar
Default Re: question about intercooler pressure drop (Prod)
If you had no pressure drop, you would get no residence time for the air in the IC.
You will always have a drop at the IC otherwise you'd get no cooling (since the air passes right through what is cooling it).
Old 10-25-2002, 02:23 PM
FredoSP's Avatar
may we also add a friction coeffiecient effect to this, when the heat is transferred?
Calc physics was so long ago
Old 10-25-2002, 04:24 PM
Quick 200k Mile Motor's Avatar
whats average for a bolt on turbo kit?
1.5psi drop?
Old 10-25-2002, 04:53 PM
FredoSP's Avatar
Default Re: question about intercooler pressure drop (Quick 200k Mile Motor)
that sounds right to me!
Old 10-26-2002, 08:30 AM
Default Re: question about intercooler pressure drop (FredoSP)
cool, i asked because a while back someone posted a PWR vs. Spearco IC comparison. If i could remember correctly, one had more pressure drop than the other because of core design.
RNPoo7
03-08-2005 11:46 PM
JM Performance
12-23-2002 07:25 PM
integranator
11-22-2002 12:37 AM
DSF
04-22-2002 03:39 AM
Quick Reply: question about intercooler pressure drop
