F22A in 93 Prelude
F22A in 93 Prelude
93 prelude. Do not know what motor was in it. Wiring harness has 3 plugs. 2 will plug into F22 distributor. 3rd one plugs into an external coil. Car will not run without that external coil plugged in. No Coil wire used. Internal coil in distributor fires and runs. Yes I did some searches. Any help is greatly appreciated.
Re: F22A in 93 Prelude
What distributor do I need to make this look correct? Is there a 3 plug that will go on this F22 that will work? Or what distributor that will use the external coil for the F22?
If you don't really have the time it takes to be completely and totally detailed about what kind of car you have, what kind of motor you plan on swapping in, what kind of harness you plan on using etc etc how do you expect people to help ? Should we just make a wild guess ?
Danny_EJ
10-27-2008 02:43 AM
lunatics209
08-06-2008 08:20 PM
its WANG yoO
09-29-2002 10:18 PM
