Flexible Brake Lines?
I am exploring all options to fix some hard brake line issues on my Integra and I was wondering if anyone has ever used flexible lines like the ones in this link:
http://recstuff.com/84-Inch-Trailer-Brake-Line.aspx
Essentially I need to replace the lines from the firewall back to the fuel tank. I was going to cut, flare, and union to the good sections if possible...
Any ideas here?
Any ideas here?
Re: Flexible Brake Lines?
that almost looks like pvc. wouldn't use that to replace hard lines.
would rather go the stainless brake line route.
saying that, have you checked to see how the guys do it when they do a engine bay tuck?
I have flared and made lines on my car with no experience. I would say if you can get the car. Up in the air then just make new lines but if you plan on doing this at home then just use a union on a straight section under the car it would be super easy to do and fairly cheap.
Thanks for the responses. The section of hard lines in the tunnel are rusted and corroded so I may just do the flaring and bending route. It will take some time because even the fuel lines need to be done but it will probably be the cheapest route.
Also read that even the SS braided and stuff in the link I posted can expand quite a bit.
Feel free to respond with additional ideas! Thanks!
Foster Zygote
12
02-19-2010 10:18 AM
null.
06-08-2007 10:27 PM
Paprika
11-28-2004 01:14 PM
