oil seal on diff.
Old 02-27-2013, 04:33 PM
james d's Avatar
Icon2 oil seal on diff.
change my diff. oil seal because it was leaking.. i replaced it with new seals still leaking... need help guys
Old 02-27-2013, 08:17 PM
Aquafina's Avatar
Default Re: oil seal on diff.
What transmission and what were the seal part numbers used? How did you install the new seals? How do the axles look?
Old 04-11-2013, 08:50 AM
james d's Avatar
its on a acura integra rs... i bought the car ang the guy told me the axles are new... so i said ok so its the oil seal... when i bougth the oil seal i tried fitting it on the axle before putting it in and the seal was fine.. when i test test drove it it still leaks maybe its the inner cv joint? if the axle are in the spline and locked if u move it up and down is it normal?
Old 04-30-2013, 02:39 PM
slowcivic2k's Avatar
Get a Honda oil seal, seriously, get a Honda seal. I've seen this too many times and its always been the seal. But check the seal surface on the axle for damage while its out.
Old 05-01-2013, 07:21 PM
MR.johnson's Avatar
any play in the axle when its popped in?
OOOtony
04-22-2009 10:50 PM
8083tcman
12-30-2008 08:43 PM
hammergunner
09-06-2008 10:39 PM
EFresh
07-31-2006 01:44 PM
serious
04-08-2003 03:47 AM
Quick Reply: oil seal on diff.
