Oil leak
Old 02-16-2013, 08:07 PM
mrginther1627's Avatar
Icon2 Oil leak
Hey everyone, I got my 2000 prelude back about 6 months ago and it had an oil leak from day 1. At first I thought it was the rings just burning oil however I recently did a dry and wet compression test and they were perfect results. And looking at my motor every side but the side with the exhaust manifold is wet from oil. I replaced my valve cover gasket because the oil starts around that and it is still leaking oi. Any ideas of what it could be? I am starting to think that it's the oil pressure sending unit. Oh and it mostly uses oil when it is in v tec. Any ideas?
Old 02-16-2013, 10:08 PM
96-h22a1's Avatar
Default Re: Oil leak
There are a few gaskets for the vtec solenoid (behind the distributor cap) 3 10mm bolt hold it on. I've had to replace it before. Could be cam seals as well. Got them changed when my timing belt/water pump was done. Another known leaker is the oil cooler gasket that attaches itself to your oil filter
Old 02-16-2013, 11:23 PM
Deksinjo's Avatar
Any pic?
Old 02-17-2013, 08:37 AM
I'll take pictures on Tuesday.
And hey thanks for your input I'm gonna check that stuff out, are your cam seals under ur valve cover?
Old 02-17-2013, 10:07 AM
Combatcomm's Avatar
Vtec Gasket same here.
I just troubleshoot my major oil leek to a bad Vtec Gasket just not sure if it were it hooks to the block or the triangle seam. I will lose all my oil in 2 days. Anyone know how muck the gaskets are. I was told I would have to go to the dealer for them.
Old 02-17-2013, 10:51 AM
thirsk66's Avatar
Yes you can go to the dealership or go here on eBay and find them.....http://www.ebay.com/itm/OEM-Genuine-...c68b65&vxp=mtr
And the upper triangle gasket for the vtec solenoid: http://www.ebay.com/itm/OEM-Honda-Ci...abb1ce&vxp=mtr
Old 02-18-2013, 08:50 AM
Combatcomm's Avatar
Outstanding thanks for your help!
Old 02-18-2013, 10:01 AM
Where are the cam gaskets?
Old 02-18-2013, 10:09 AM
92bluepreludeSi's Avatar
Well it could be the cam plug dizzy side of engine but on the intake cam. Cam seals are right behind each cam gear.
subtlecuddle
08-04-2015 08:52 AM
roadrunner1
03-03-2007 05:34 PM
Jeff
04-18-2005 06:23 AM
98cwitr
04-27-2004 01:34 PM
notsure
10-10-2003 12:08 PM
Quick Reply: Oil leak
