Help with VSA Light!
Old 02-10-2013, 09:21 PM
outlier25's Avatar
Default Help with VSA Light!
Hey Guys!
Im having a problem with my 07 civic si. The VSA light and the /!\ Traction control light are on.
I pulled the codes and they are as follows:
86-11 Fcan Communication with ecm/pcm
83-13 ECM/PCM relation failure.
I believe this light came with I short circuited a wire on accident (touched the grounding wire and the power wire) I check every fuse under my dash and under the hood but they all seem to be good.
Can anyone help me diagnose this problem? I couldnt find much info on those codes. I have a multimeter but not sure what needs to be tested or what/where the PCM or ECM is.
Old 02-11-2013, 01:38 PM
97emsedan's Avatar
Default Re: Help with VSA Light!
Throttle position sensor not working...take it to the dealer and get a price... when mine went out on me..twice... I was lucky enough that it was under warranty...I hear they aren't cheap...
It seems that they aren't connected to the VSA, but they are... I asked the techs when they did the work...
Old 02-12-2013, 05:42 PM
outlier25's Avatar
But doesn't the TPS Sensor have its own code?
Old 02-13-2013, 05:46 PM
97emsedan's Avatar
not according to the mechanics at my Honda dealership... the syptoms you gave me were identical and both times it was the tps...
Old 02-19-2013, 04:41 PM
SirProject's Avatar
according to the dtc troubleshooting it needs either a pcm software update (available at a honda dealership) or a pcm
SirProject's Avatar
thats straight from hondas diagnostics (i work for honda)
Old 02-24-2013, 11:35 PM
outlier25's Avatar
what exactly is a pcm and where is it located?
BrayzieEF9
01-14-2010 10:01 AM
C-West Civic
12-18-2007 04:34 PM
Gyoung145
09-30-2006 05:58 AM
vthree
05-06-2006 03:56 PM
Quick Reply: Help with VSA Light!
