Gen 1 Trunk Pop Fuse?
I Was trying to get my Viper alarm aux button to pop the rear glass. Figured out how to do it, but realized that I am going to need a relay . The alarm gives a negative signal when the aux button is pressed so I thought "Hey I bet I could test if it would work with a negative to the battery!" Wrong. Touched the positive trunk wire to the negative battery wire to complete the circuit and got a little spark. Now there is no longer a 12 volt drop across the trunk button, so I am assuming I blew a fuse somewhere. Everything else in that car works, and I can't see a fuse for the trunk release in the cabin fuse box. Where is the fuse that controls the trunk release button? Or did I burn something out that will take a bit more effort to fix ?
Thanks so much!
TLDR: Where is the fuse that controls the trunk release button?
Thanks so much!
4doorH22
11-27-2001 09:48 AM
