Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Element & CR-V
Old 02-05-2013, 04:03 PM   #1
razcob
Default Where is crankshaft position sensor located 01 CRV
Where is the crankshaft position sensor located on 01 CRV?
How do you test this part?
razcob is offline   Reply With Quote
Old 02-05-2013, 05:07 PM   #2
LDForget
1998 Honda CR-V
LDForget's Avatar
Default Re: Where is crankshaft position sensor located 01 CRV
in the distributor.
98 EK Hatch, built JDM GSR, Precision 5831,JE pistons, eagle rods, ect, ect, ect.
December 2012 Ride Of The Month My CRV Build Thread - deceased
LDForget is offline   Reply With Quote
Old 02-06-2013, 02:31 AM   #3
razcob
Originally Posted by LDForget View Post
in the distributor.
Where is it in this bernardi parts diagram?
http://www.bernardiparts.com/SearchO...onda-crv-parts
Is there a sensor that attaches to the engine?
2001 crv lx 4wd
Old 02-06-2013, 03:20 AM   #4
LDForget
1998 Honda CR-V
LDForget's Avatar
sorry i thought you said cam sensor. if i remember correctly, its on the top/rear of the crank pully, under the water pump. might be able to get it from the wheel well.
Old 02-06-2013, 03:26 AM   #5
LDForget
1998 Honda CR-V
LDForget's Avatar
youve gotta pull off the pully to get to it. Youre going that far, you should change your timing belt and water pump while youre there if you havent already.
Old 02-07-2013, 12:27 PM   #6
HondaPartsHero
Technical Hero
HondaPartsHero's Avatar
Do you have a check engine light code?
OBD1/2 SOHC/DOHC VTEC HARNESS
MINI ME SUBHARNESS
02 EXTENSION HARNESS
Hondapartshero.net
HondaPartsHero is online now   Reply With Quote
Old 02-07-2013, 02:48 PM   #7
blackaneseman
blackaneseman's Avatar
http://torontohondaparts.com/PartsLi...ine&illid=9153
Located with the oil pump
LEVEL ONE
WWW.TORONTOHONDAPARTS.COM
MUGEN EJ1
blackaneseman is offline   Reply With Quote
Similar Threads
crank sensor on my CR-V grimybill Honda Element & CR-V 8 07-29-2013 12:30 PM
P1361 TDC Sensor jrotola Honda Civic (2001 - 2005) 2 07-21-2013 06:31 AM
Crankshaft Position Sensor BigbamaBen Honda CRX / EF Civic (1988-1991) 5 03-17-2013 12:09 AM
sensors sapphire32 Acura Integra 2 10-09-2012 12:15 PM
crankshaft position sensor issues darkslash Acura Integra 36 10-08-2012 06:31 AM
