Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 10-20-2002, 07:11 PM   #1
NONKonformyst
NONKonformyst's Avatar
Send a message via AIM to NONKonformyst
Default Throw-out bearing in need of greasing....
My car recently started to make a chirping noise that goes away when the clutch pedal is depressed. I've come to realize that its the thowout bearing in the clutch assembly. My question for you guys is, what should I use to grease this? What things do I need to look out for when opening up the clutch assembly? Roughly, how long should this take myself and one other person? I've got the Helms so guide me, but personal experience would be appreciated. Thanks.
-Ryan
1994 Mazda Miata C package
2003 NBP EP3
1995 Prelude VTEC
1993 Prelude S
1998 B16 swapped EK
NONKonformyst is offline   Reply With Quote
Old 10-20-2002, 07:47 PM   #2
Cottonwoodz
Cottonwoodz's Avatar
Default Re: Throw-out bearing in need of greasing.... (95redLUDE)
Did you just get a clutch installed?
[quote=ludesrv]I ran 14.8 with my[i] [b]stock[/b][/i] 93 SRV, [i][b]I/H/E[/b][/i]. On 17s.
I've seen a 5th gen with the same mods and a JDM H22 run a 15.2 against me.
[b]I've also ran a 16.2. Depends on the driver.[/quote] [/b]
03' Touring Z33 #5503 I/H/E/C/ECU [B]TUNED[/b]
92' Prelude Si #9167 H22A I/H/E/fw/[b]2695lbs[/b]
91' GMC Syclone #2418 [b](Under construction) [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
[b][url="http://www.zfilms.org/SportZMag/DynoDay2003/350Z-NismoExhaust.mpeg"]http://www.zfilms.org/SportZMa....mpeg[/url][/b]
Cottonwoodz is offline   Reply With Quote
Old 10-20-2002, 08:17 PM   #3
bgod
Default Re: Throw-out bearing in need of greasing.... (Cottonwoodz)
no point to grease it. just get a new one. you're gonna have to remove the tranny.
DSF: Bogarts/slicks
2point6: rockers
hot_EG: Jun header
aklucsarits: Jun flywheel
ls_vtec_b18a1: Skunk2 cover
RacerBoy: H&R's
PhAtBoY Si: GSR seats
anduwutgsr: resonator
sauceman, MugenHonda, Toda Party: HID's
Dan GSR: rollbar
95hbMatt: mount
JDMFIEND: HCP kit
MattGSR, maggsgsr, Gritsak, Migs: interior
b18bturbo: JE's
GSRTUNR: headlights
TypeGSR196: bumpers
deviant94ex: rear discs
boosted hybrid: avcr
honda_joe: shift ****
TypeR507: dc bar
bgod is offline   Reply With Quote
Old 10-20-2002, 09:21 PM   #4
NONKonformyst
Yeah, but I believe the Honda warranty is now expired. Instead of paying a **** load to have them do it I'm just gonna do it myself.
-Ryan
2003 NBP EP3
1995 Prelude VTEC
1993 Prelude S
1998 B16 swapped EK
Old 10-20-2002, 10:20 PM   #5
Jonathan_ED3
Jonathan_ED3's Avatar
Send a message via AIM to Jonathan_ED3
High Temp wheel bearing grease works good Click the image to open in full size.
Even if he does put in a new one, the new one would still need to be greased too. Either way, a good greasing is called for. Click the image to open in full size.
[Modified by hot_EG, 1:21 AM 10/21/2002]
My Vouch Thread
'79 Civic w/d16z6, '83 Civic S w/d16z6, '85 RX7 w/LS1/T56, '78 Corolla w/LS1/T56, '06 TSX -stock.
Jonathan_ED3 is offline   Reply With Quote
Old 10-21-2002, 02:43 AM   #6
jc836
jc836's Avatar
Default Re: Throw-out bearing in need of greasing.... (hot_EG)
WHAT-throwout bearings are not greased in the field. They are either good or need replaced. We are talking about the bearing-not the fork or linkage here.
As was asked-did you just replace the clutch and not the bearing If so that iis your problem. You will have to take the tranny out to fix this. Click the image to open in full size.
Grandpa's Toys-Modded suspensions and a few other tweaks
'89CRX Si= SCCA/NASA/PDA HC4/ITA #99
'04 RSX still in original trim
'03 Dodge Dakota Club Cab -Gonna tow
Thanks to Koni, KIRK Racing, Longacre, Racing Electronics, UPR-racing, Firefox Industries - Fire Supression Systems, and a host of others http://images.honda-tech.com/set1/smile/emsmile.gif
jc836 is offline   Reply With Quote
Old 10-21-2002, 05:27 AM   #7
bgod
Default Re: Throw-out bearing in need of greasing.... (jc836)
greasing the throw out bearing is just a temporary solution. you can however grease a new one before putting it in.
but either way, a new one is in order.
DSF: Bogarts/slicks
2point6: rockers
hot_EG: Jun header
RacerBoy: H&R's
Dan GSR: rollbar
95hbMatt: mount
JDMFIEND: HCP kit
b18bturbo: JE's
GSRTUNR: headlights
TypeGSR196: bumpers
TypeR507: dc bar
Old 10-21-2002, 07:37 AM   #8
BoostedH23a1
BoostedH23a1's Avatar
Send a message via AIM to BoostedH23a1
Default Re: Throw-out bearing in need of greasing.... (bgod)
dont grease the surface that hits the clutch! just the pilot shaft. if u hear it its time for a new throw out. its only 40 dollars man
SELLING MY CAR
---94 Turbo Prelude---
[url=http://www.angelfire.com/sc/leenash/index.html[/url]
94 Prelude Si 260 Whp @ 6psi 224.9 tq
BoostedH23a1 is offline   Reply With Quote
Old 10-21-2002, 05:48 PM   #9
2001se
Default Re: Throw-out bearing in need of greasing.... (BoostedH23a1)
After you change it out, something to keep in mind: You can prevent wear on the throwout bearing if you don't leave the clutch pedal pushed down while you're waiting for long lights, etc.
2001se is offline   Reply With Quote
Old 10-21-2002, 07:07 PM   #10
NONKonformyst
Like I said, I did just get the clutch replaced but I bet it is the same bearing. If it's making the noise then most likely it needs to be replaced, is that what you guys are saying? Does anyone have the part number by any chance? Thanks a lot for your replies, but how difficult is it to remove the tranny?
-Ryan
2003 NBP EP3
1995 Prelude VTEC
1993 Prelude S
1998 B16 swapped EK
2000, 94, accord, bearing, change, dakota, dodge, grease, greasing, honda, miata, noisy, prelude, replace, throw, throwout
