Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 01-16-2013, 04:44 PM   #1
ThePizzaMan
ThePizzaMan's Avatar
Icon3 Seat belt retractor question, went to Honda...
I've had a problem with my seat belt retractors, won't lock when pulled on and flashing seatbelt light on dash. Took to Honda, they ordered two retractors and replaced. I leave the dealership today after they replaced both retractors and I still have the same issue. Any suggestions as to what it might be the cause? Thx!
ThePizzaMan is offline   Reply With Quote
Old 01-16-2013, 04:56 PM   #2
kaiba
kaiba's Avatar
Default Re: Seat belt retractor question, went to Honda...
Take it back to honda. Dont **** with it.
kaiba is offline   Reply With Quote
Old 01-21-2013, 02:55 PM   #3
ThePizzaMan
They took it back, looked at it again... said the problem is with the door latch, and that they can't repair it because that part is no longer made. Why would the door latch cause the seat belt light to be on? The dome light sensor in the doorjamb works just fine, and the door closes and opens okay (with the exception of sagging hinges in the front).
Any ideas?
And/or, is there a fix for this?
Old 01-22-2013, 09:32 AM   #4
v4lu3s
1989 Honda CRX
My Garage
Send a message via AIM to v4lu3s
i would ask them specifically to explain how the door latch is affecting your seatbelts. the technician and service writer should be able to do that, it is their job.
v4lu3s is offline   Reply With Quote
Old 01-22-2013, 12:11 PM   #5
thedaltonator4
ya whatever you do. DONT mess with it!!! same thing happened to mine and then the one thing you dont ever want to jerry rig. your seatbelt.
thedaltonator4 is offline   Reply With Quote
Old 01-22-2013, 12:36 PM   #6
i64X
i64X's Avatar
If I remember correctly the electronic switch that tells the car if your seat belt is buckled or not is in the part of the belt with the button on it that bolts to the center floor of the car in between the seats. The mechanism in that button could be broken, which would have nothing to do with the safety of your seat belts. There should be an electrical connection for that switch under the seat. I've seen people bypass the warning light with a paper clip or a small piece of wire if they put aftermarket seats in their EFs with harnesses vs the stock seat belts.
i64X is offline   Reply With Quote
Old 01-22-2013, 02:08 PM   #7
ThePizzaMan
How did you fix it?
There is also an electrical draw that appears to be somewhere in this circuit, others have complained of seatbelt lights/power draws.
Also, do your seatbelts lock if you tug on them? I can't get the seatbelt to lock... this is my primary concern.
Old 01-22-2013, 03:10 PM   #8
ThePizzaMan
He said "There is a connection on the latch inside of the door that is no good". This is where the problem is according to Honda.
Old 01-22-2013, 03:50 PM   #9
KWayRacing
KWayRacing's Avatar
I have seen many door latches cause the passive restraint system to not work properly. However that shouldn't cause the problem you describe in your original post. Seatbelts will not lock. Does this mean the seat belts do not slide from front to back when you close the door? Exactly what does will not lock mean? The door latch has a switch in it that tells the seatbelt control unit to slide the seatbelts from front to back or vise versa depending on its position.
KWayRacing is offline   Reply With Quote
Old 01-22-2013, 07:29 PM   #10
ThePizzaMan
If I yank on the seatbelt, while breaking, driving, the belt won't hold me back.
Old 01-22-2013, 07:33 PM   #11
bheinen74
Theeeee most common issue on a crx is the seatbelt retract not working right causes cuts on the door panels. Second most common is glovebox mount point breaking, 3rd is the hvac clamp back side cracking causing no hot cold control. 4th sunroof on si not working right
have had many Honda's
currently own:91 CRX Si, 91 CRX si, 88 CRX Hf, 85 BRAT GL, 04 Subaru Outback
bheinen74 is offline   Reply With Quote
Old 01-22-2013, 08:41 PM   #12
ThePizzaMan
Cuts on door panels?
Old 01-22-2013, 09:16 PM   #13
Spug
1990 Honda CRX
Spug's Avatar
When you close the male side of the buckle in the door when the belt doesn't retract, causing gouges on the rear end of the door panel.
Paintball's Homepage
Spug is offline   Reply With Quote
