Old 01-11-2013, 07:09 PM   #1
Tampacb7813
Default 1992 Accord sputtering and backfiring out of throttle body... FRUSTRATED!!
So this car has been hell trying to figure what is wrong with it!! I thought it was a fuel delivery problem........ I have replaced the fuel filter.... fuel pump. And still has not changed. So I replaced the coil, cap, rotor, wires and plugs still has not changed. Changed map sensor, checked main relay..... I have spent $600 on this car all ready!! It takes awhile to start.... and once it starts it fires on all 4 cylinders until you give it throttle and it starts sputtering like crazy, and starts backfiring out of the intake.... Please any help. Im so frustrated and stressed......
Tampacb7813 is offline   Reply With Quote
Old 01-11-2013, 07:10 PM   #2
Tampacb7813
Default Re: 1992 Accord sputtering and backfiring out of throttle body... FRUSTRATED!!
BTW I am getting a CEL code # 41 which is a bad oxygen sensor.....
Old 01-11-2013, 07:40 PM   #3
themiz816
@ejshelt
have you replaced the o2 sensors then?
Posted from Honda-tech.com App for Android
1998 Honda Accord EX 4 cyl Vtec 2.3L
1995 Honda Civic EX 4 cyl 1.6L
themiz816 is offline   Reply With Quote
Old 01-11-2013, 07:54 PM   #4
jdowen2
2001 Honda Accord
jdowen2's Avatar
Check your timing. Belt may have jumped a tooth.
2013 Accord V6 coupe, auto 2001 Accord V6 EX coupe
1988 Corvette coupe
1967 Ford Mustang GT clone
jdowen2 is offline   Reply With Quote
Old 01-11-2013, 08:28 PM   #5
Tampacb7813
yes
Old 01-11-2013, 08:29 PM   #6
Tampacb7813
I dont think it is the timing belt because there are times when it runs perfect... and it is not sputtering or backfiring. It will run fine for about 2 minutes then start acting up. Could the ignition module be the culprit?
Old 01-12-2013, 03:44 AM   #7
GhostAccord
1996 Honda Accord
GhostAccord's Avatar
Backfiring out the intake is usually a condition relative to a timing or ignition issue. That or a bent or burnt intake valve.
Where it takes a long time to start. Have you replaced the battery or had it tested?
Have you done a compression test or leak down test on the engine?
What did the old spark plugs look like and what do the new ones look line now? The condition of the spark plugs can tell you a lot about the combustion conditions in the engine.
GhostAccord is offline   Reply With Quote
Old 01-12-2013, 05:46 PM   #8
Tampacb7813
The number 3 and 4 cylinder plugs were very black.... and number 1 and 2 plugs were normal
Old 01-12-2013, 05:48 PM   #9
Tampacb7813
Havent done a compression test..... Took the cam gear cover off and put the bottom end in time and the top end was off a little less then a tooth
