Parachute mount and location
Old 01-10-2013, 02:30 PM
ekcoupeh22's Avatar
Default Parachute mount and location
ok so I've been searching around for a parachute mount fir a while now with no such luck I want a removable setup I don't want it permeant I can't seem to find what I'm looking for I'm looking for one that bolts into the tube. Like this one would be perfect
2nd where is the most ideal location for the anchor line? Higher the better?
Old 01-10-2013, 02:42 PM
theidealone's Avatar
Default Re: Parachute mount and location
https://swracecars.com/store/Parachu...OSCAR_364.aspx
Obviously too high could be a bad thing. I would think centerline of gravity would be optimal, but thats just my logical guess.
Old 01-10-2013, 02:49 PM
ekcoupeh22's Avatar
You know how many times I looked at that chut mount and never saw the bolt? Smh
Yeah I was thinking right above the license plate?
Old 01-10-2013, 04:55 PM
redboost10's Avatar
That style looks like a trailer hitch. Believe it or not jegs has a nice kit that you can use or just make it yourself. Make the bottom tether section came out of the center of the bumper and make it removable. Then the parachute mount can be off the license plate section, so your trunk is still functional too
Old 01-13-2013, 02:09 AM
ineedavtec's Avatar
I had one fabbed that looks pretty close to the one you have in the pic but the chute mount is up higher and the bar going to the chute mount itself is set back farther and bends twords the back of the car instead of away, kinda hard to explain, I dont have pics of it on the car on this comp, but I'll try to get one in a bit when I go down to work on it, if you think that might help. Only pic I have on photobucket is how the inside fab work looks that it goes into.
Old 01-13-2013, 02:11 AM
ineedavtec's Avatar
I didn't look hard enough, found it lol
Old 01-13-2013, 08:07 AM
ekcoupeh22's Avatar
That's a nice setup but that would be way to high on my integra cause I have a drag wing for it
Old 01-13-2013, 08:35 AM
sohc95vtec-t's Avatar
How mine was done. Boxed in the rear "frame rails" where the stock bumper bar bolted in, and ran a bar to each side. The chute is removable just like the one you showed
Old 01-15-2013, 12:37 PM
turbodano's Avatar
The chute should be attached/anchored no higher or lower than 2 inches of the top of the tire.
Old 01-15-2013, 06:22 PM
nonvtecallmotor's Avatar
Mine is done like the Del Sol. I didnt want monkey bars in my trunk..
Old 01-16-2013, 08:20 AM
wreckeddc4's Avatar
Chute does not have to be tied into the cage?
Old 01-16-2013, 08:22 AM
redboost10's Avatar
Nope. Mine is like the del sol as well. You can lift the car by it.
Old 01-17-2013, 04:30 AM
EJ1_Ex's Avatar
Im interested in a setup like this..
Old 01-17-2013, 08:02 AM
E Town DSM's Avatar
I think the guys at nrg tech sell a bolt in kit for the mount and the handle
Old 01-17-2013, 09:17 AM
EJ1_Ex's Avatar
I'll check them out
Old 01-19-2013, 05:18 PM
ekcoupeh22's Avatar
[QUOTE=E Town DSM;48346398]I think the guys at nrg tech sell a bolt in kit for the mount and the
Old 01-20-2013, 03:16 PM
ekcoupeh22's Avatar
Anybody else know where I can get the one pictured?
Old 01-21-2013, 07:22 AM
MR.johnson's Avatar
bump looking into different kits and chutes. what works good?
Old 07-22-2014, 01:06 PM
Steeve_Civic's Avatar
I m interested for a bolt on kit, is there some others feedbacks?
Old 07-22-2014, 06:37 PM
DOHCarp's Avatar
Here is something I found while I was looking for the same. Ended up fabing up something similar. I don't know the company or have ever purchased from them before.
http://www.turboelements.com/index.p...product_id=146
Old 07-22-2014, 06:51 PM
carbon fiber coupe's Avatar
chute0000 by 93 red ls, on Flickr
chute000 by 93 red ls, on Flickr
chute00 by 93 red ls, on Flickr
Old 07-22-2014, 08:39 PM
Ron Burgandy's Avatar
Where do these specs come from? Most chutes sit up where you describe, but almost all that I see have their anchor points well below that.
honda_soldier
18
12-30-2011 04:12 AM
Crazy_SI_T
10-24-2011 09:43 AM
lmike6453
06-26-2008 01:45 PM
kommon_sense
12-10-2007 08:15 PM
civic disobedience
06-12-2003 03:55 AM
Quick Reply: Parachute mount and location
