leaking coolant out the head
hi everyone. just did a head gasket in my 97 civic minime d16y8 block / y8 head. when i took off the old gasket there was no crack. head and blicked looked good was gona send out the head but decided not to. anyway, i replaced all the gaskets on the car, new head bolts torqued tospec. and sequence. new locking nuts for the intake / exhaust mani. and new oil / filter / coolant. started it up earlier today for the first time and started click of a key! no check engine no nothing. ran excellent then after about 5 mins i noticed the top right of where the head meets the block is slowly leaking coolant. it wasnt leaking before i did all of this so anyone wana give me suggestions now? im tired of working on this car rly dont wanavtake the head off again (prolly going to) fyi i used aftermarket felpro gasket not sure if it might be slightly different then the oem. pretty sure i got the gasket on the right way it only went on 1 way to allighn with all the holes so idk pls help
Re: leaking coolant out the head
Did u get ur head cylinder resurface? All aluminum head need resurfacing from machine shop every time u take the head off to ensure flat surface to evenly mate to the block. Even if if the head cylinder looked even I'd still get get resurface a lil to b on the safe side cause I know head cylinders are a lot of work.
When u remove head cylinder again you'll have to get another head gasket sorry to say.
yeah. . didn't get it re-surfaced figured i could jus throw a new gasket on and be good since my old one wasnt cracked. i replaced the gasket in the first place for a few reasons. 1. was getting white stuff under the oil cap (i guess its just condensation) and 2. water droplets coming from the exhaust with white smoke. when i pulled out the fuel rail / injectors i noticed one of the injectors (injector 4) the tip of it was cracked. so i assume gas was jus running through this thing and going into my exhaust? either way ill replace the injector. but back to my head. . yeah idk, honestly i think im jus gona try to re-torque it down, maybe torque the part where the leaks commin from a few more pounds. 49lbs is recomended which is what i torqued everything at in sequence. if still leak im just ripping off the head and gona send it out to be checked. -.- rly tired of working on this car i jus wana drive this lil ricer
Yea head surface might not be even or also if u didnt clean out the head bolt holes from the block, might have oil or debris in ther and then when u put ur head bolts on could cause u not to torque it down correctly.
Idk where you are from but I got a P4 port and polished ready to go kn a B series if that's what your running........I'm takn best offers on it got it for cheap my boy said its ready to go on ill prob sell it for 150 bucks
problem is fixed! took off the head AGAIN and the gasket was bent in the corner it was leaking from, duno how the F$#^ that happened, w/e im a DUMBA$$ lol. . anyway, put ANOTHER HG on put it all back together and its all gravy, no leaks, no overheating, everything running pretty smooth.
would anyone be able to inform me on how much it would cost to resurface my block? and what the procedure would be (prep before i take it to the machine shop)?
yea i live in new haven CT i kno a shop that decks n sand blasts for like $120
as far as prep work i would jus clean n degrease it even tho the'll prolly blast it anyways... idk
Robotin
03-24-2012 04:03 PM
