FS: Race Parts or Supplies
#26
Re: FS: Race Parts or Supplies
For sale: Volk TE37 Super Lap Edition 15x8 5x114 +32 Magnesium Blue. Have original box and valve stem caps. Does not include tires. Wheels are in good condition without any curbs or bends.
Price: $2050 picked up.
CELL: (SIX TWO SIX) 679-7263.
Loaction: Rosemead CA
#28
Near new condtion powder coated car hauler (less than 2000mi). Tires and brakes are in excellent shape, aand is stored in a climate controlled shop so there is no rust. There is a lockable 8x2x3 powder coated cargo box on the front of the trailer for storage. Very sleek and low design with long gentle beavertail makes loading low ground clearance race cars a breeze. Ramps slide out from under the deck, no lifting or straining required! Located in Central OH - $2750 You can email me directly fred (at) crxmotorsports (dot) com.
#33
Vibrant Racing Header, 4-1, T304 Stainless Steel. Vibrant Part Number 2509. Fits Honda B16, B18, or B20. $300 obo. Need cash. Motivated seller. I'm in Encino, CA. Prefer not to ship due to size.
#34
FSLIC red FAL fans for 96 to 01 integra. In very good shape. I never used them since they do not fit well in an EF. PM me if interested.
#37
#39
I have a bunch of suspension parts for sale:
pair of 2.5" x 7" 800# Hypercoil springs, NIB. $60
set of 4 Apexi N1 springs, new without box. Came on a set of N1 Pro dampers that had springs swapped out before installation on vehicle.
pair 2.5" x 7" 336# / 6kg
pair 2.5" x 7" 560# / 10kg
$100 for all 4
set of 92-95 Civic / 94-01 Ground Control coil over sleeves for KONI shocks, ~2500 miles, ***NO SPRINGS*** $150
pair of ground control top hats for 92-95 civ / 94-01 integra ~2500 miles $SOLD
Set of Koni 8041-RACE revalved+shortened shocks for 92-95 civ / 94-01 integra. ~2500 miles. REAR shocks are in good shape. ***ONE FRONT SHOCK IS BLOWN*** over $1000 new asking $350
Or $500 for everything listed here. I have stuff listed locally on craigslist for more money. I'll try to keep this updated if people buy stuff.
Everything is located in Cincinnati, Ohio zip 45213 for calculating shipping.
***I DO NOT CHECK HONDA-TECH VERY OFTEN SO PLEASE EITHER EMAIL ME OR CALL ME***
blundar at gmail dot com
five1three four ate four thirty twentynine
Thanks,
-Dave
$100 for all 4
Thanks,
-Dave
#41
Comes with everything in the pictures. Just unbolt your setup and bolt this up and go. As you can see from the pictures inside the rotor the pads still have a ton of life left. 2 piston calipers, 11" rotors, 3mm spoon spacer, hawk brake pads, larger spindle with arp extended studs. Uses stock brake lines. Was on my EG so should fit quite a few different chassis.
Only reason im selling is because i went with smaller brakes for drag racing.
1200.00 SHIPPED AND PAYPAL
Phone number is 828 850 5974 if you have any questions. I dont check honda-tech at all really. So please text.
#42
Eibach Anti-Roll Bar Kit (Rear Only) 25mm
Sold!
I still have the Original Box if you want it shipped or I can just wrap the bar in bubble wrap and send it!
The Blue Tape Is to Hold the Screws and D Bracket together so they don't get misplaced
#45
For Sale:
Aluminum Crank Pulley with matching Gates belt - only ran it shortly. No issues. (Ignore the part number on the belt I just used the sleeve from another size to store the belt.
$70shipped in the US
Located near Detroit
PM me please
PM me please
#46
Hey guys I am selling a few parts that I was going to use on my 97 Ek race car. Car was sold due to lack of time to track. All of these parts were purchased from Jeff - Kiwi at Special Projects MS...
I am selling the stuff cheap as I would like to move it rather quickly. All parts are brand new, never used.
Paypal is fine with me and all parts will be shipped UPS.
Anyone interested feel free to email me: martin.dettelbach@gmail.com
Gear X AC107 5.08 Final Drive for K20 - $500
GX AC107 Integra DC5, EP3 ’02- K20 DOHC ROAD RACE This Final drive is best suited for most Road Racing applications. If using Stock Gear Ratios. And it works extremely well with the GXHO-K CR2 Close Ratio Gear Set
Gear X GXHO KCR2 - $1500
http://www.specialprojectsms.com/gear-x/gxho-k-cr2.html
Designed as a Drop in replacement Kit.
1st, 2nd. 3rd, 4th , 5th, 6th.
Suitable for full race K-20 or K-24 where very close ratio
applications are required, such as road and gravel rallying.
Sprints, hill climbs or road race. Works extremely well with
a 5.06 or 5.08 Final Drive.
Ratios: 1st - 2.313 2nd -1.650 3rd -1.304 4th - 1.080 5th - 0.958 6th - 0.851
Kit consists of: A custom Main shaft, 4 custom Main Shaft Gears and Six Counter Shaft Gears.
Carbon Synchro's for DC5 Dual Cone 1-6 $125
#47
FS: Type R/JDM Y21 Hydro Trans w/CUSCO LSD & Gear X 4.92 Final Drive
FS:Type R/JDM Y21 Hydro Transmission w/CUSCO LSD-Gear X FD
I'm selling my hydro JDM Y21 SIR II Transmission (B-Series)
Each gear ratio (1-5) is the exact same as Type R
GEAR X 4.92 Final Drive
Gearspeed Carbon Synchros
CUSCO (clutch type) LSD
***used 6 race weekends
$1850......buyer pays shipping, I'm located in Sacramento, CA
if interested, email me: vtecjj@yahoo.com
#49
1 Post
Planted seat bracket and side mounts
Planted Seat Bracket
*driverside only
*fits 92-95 Civic or 94-01 Integra
*made with 3/16" thick steel and powder coated black
*accepts sliders from most major seat manufacturers like Bride, Cipher Auto, Cobra, Corbeau, Momo, OMP, Racetech, Recaro, Sparco, Status
*extra material is provided for direct seat or side mount applications where eliminating sliders is preferred
Planted Steel Side Mount
*made from 1/8th inch thick steel (complies with FIA's required thickness) and powder coated black
*will fit side mount seats offered by: OMP, Cobra, Status, Racetech, Sparco, Recaro & Bride for sure, and will most likely fit most other seat manufacturers but have not been test fitted.
$135 shipped
if interested send a text to: 480 two one three 0861
*driverside only
$135 shipped
#50
My Name is Nobody
Koni 2812's for sale.
These were built specifically for the cs2 chassis, but I am sure they will fit other chassis being long body 2812's and having typical honda mounts. No springs, just shocks. they have a few thousand miles on them now, but are in great condition... as normal, they were originally over $1,000 each.
located in Las Vegas
looking for 2500$ + shipping
Contact here via PM
OR BEST OFFER!
Contact here via PM
OR BEST OFFER!
