GSR Brake Conversion into 99 Civic Cx
Old 12-29-2012, 06:31 PM
kidari's Avatar
Default GSR Brake Conversion into 99 Civic Cx
After the installation, I'm getting lots of road noise from outside.
All parts came off of a 98 GSR. What can I do to get rid of this noise?
Old 12-29-2012, 06:59 PM
Master Detailer
98civdx's Avatar
Default Re: GSR Brake Conversion into 99 Civic Cx
If you don't describe the noise, how can will help?
Old 12-29-2012, 07:28 PM
kidari's Avatar
It sounds like excess road noise or wind.
Old 12-29-2012, 08:19 PM
ekb16's Avatar
bad wheel bearing maybe?
Old 12-29-2012, 10:48 PM
Master Detailer
98civdx's Avatar
Check the wheel bearings.
Old 12-30-2012, 12:05 AM
kidari's Avatar
Checked, zero play or noise. I'm going to check tomorrow and see if my brake dust shield is rubbing.
Old 12-30-2012, 01:09 PM
jbpnoman's Avatar
a rubbing dust shield isn't going to create road noise, it would create a grinding or scraping sound.
Old 12-30-2012, 02:57 PM
kidari's Avatar
You're right, apparently it's this:
3. 99-00 Si Emergency brake lines (integra lines will work but they come together into a single rubber floorpan grommet which you'll have to hack up and you could hear wind noise, etc under the carpet).
:\ ... any creative suggestions on how to take care of the noise instead of getting new Si e-brake lines?
Old 12-30-2012, 03:26 PM
Master Detailer
98civdx's Avatar
What's wrong with the break lines?
Old 12-30-2012, 03:32 PM
The Grumpiest
grumblemarc's Avatar
Nothing. They hacked up the pass-through grommet which allows all the road noise through.
Old 12-30-2012, 03:37 PM
jbpnoman's Avatar
Get some white silicone caulk from your local hardware store and caulk the **** out of the hole.
Old 12-30-2012, 03:51 PM
Master Detailer
98civdx's Avatar
ohhh...
Does Honda sell them separate or only with the cables?
Old 12-30-2012, 04:39 PM
kidari's Avatar
lol, I may just try that. Silicone is not corrosive but it is flammable. Any other suggestion?
I'm stopping by the dealership to pick up some cotter pins tomorrow. I'll inquire to see if by chance they sell the grommet. I highly doubt it though.
Old 12-30-2012, 05:20 PM
jbpnoman's Avatar
Not all forms of silicone are flammable, but either way, that particular part of the car doesn't get anywhere near hot enough for it to be a concern.
HC4
Honda CR-V & Element
07-04-2019 05:45 AM
2gnarly
06-26-2011 09:43 AM
StockEm2
Suspension & Brakes
06-18-2009 11:10 PM
lazychina
08-20-2008 05:45 PM
Quick Reply: GSR Brake Conversion into 99 Civic Cx
