2000 accord v6 EGR port cleaning
Old 12-15-2012, 08:23 AM
F16pilotjd's Avatar
Default 2000 accord v6 EGR port cleaning
Have 2000 accord with 175k. Shop changed EGR valve twice and engine light comes on following 10 miles of driving. Heard so tech bulletin 99-085 to clean the EGR ports. Any tips on removing the intake manifold and cleaning ports? Any other routine maintenance I should perform while intake is off?
Old 12-15-2012, 10:35 AM
jdowen2's Avatar
Default Re: 2000 accord v6 EGR port cleaning
FAQ: http://www.tegger.com/hondafaq/tsb/accord/A99-085.pdf
Old 12-17-2012, 05:33 PM
F16pilotjd's Avatar
Thanks. This should help.
Old 12-18-2012, 09:20 AM
F16pilotjd's Avatar
While I have the intake manifold off do you recommend any routine service? Can I get away with just cleaning the ports and not installing the $147 plastic tube?
Old 12-18-2012, 01:55 PM
jdowen2's Avatar
Clean throttle body and IAC.
Old 12-19-2012, 02:45 PM
F16pilotjd's Avatar
Jdowen2,
This may seem a little basic, but just spray with carb cleaner? Any seals I need to be concerned with?
I am an old plane mechanic and pilot so this newer tech stuff is a challenge to do correctly for the layman.
Thanks
Old 12-19-2012, 04:01 PM
jdowen2's Avatar
Need gasket for throttle body. Just spray with throttle body cleaner. I think carb cleaner is more corrosive but not sure.
shawnvtecordie
02-09-2018 07:35 AM
WizardOfRoz
05-22-2015 08:37 AM
sween16
10-22-2012 04:42 PM
jojogalan
07-18-2007 12:30 PM
Din
11-16-2006 09:01 PM
Quick Reply: 2000 accord v6 EGR port cleaning
