96 accord code p0720 tried everything! hellppp...!!!
ok so im new to the forums considering i can fix mostly anything on my cars but i find this forum very helpful nd ran into a little problem with my car and was hopeing maybe u guys can hellppp!!! so i have a 96 accord wagon,auto about 152k about a year ago my check engine light came on and the d4 light started blinkin at the same time i ran the code it came back p0720 countershaft speed sensor circuit, the car ran and shifted fine nd speedo still worked but i wanted my light out so i located the outputshaft speed sensor and replaced it soon as i drove light came bak on! so then i figured maybe the sensor was bad i tried another,same thing so then i even replaced other two sensors,light still on! after that i checked wiring harness and plugs no breaks in wires and plugs are clean?! so since my car is 96 and tcu (trans comp) is built into ecu i changed the ecu,light came rite bak on! after that i got fed up and although my tranny worked fine i went nd pulled another tranny with all 3 speed sensors and put it in drove about 3 miles and light still came on!!! uggghh! i have to pass emmisons this month and have to turn check engine light out can any one help? any help would be great... thanks!!!
Re: 96 accord code p0720 tried everything! hellppp...!!!
thats wat i thought maybe tranny workin fine but is really bad but tranny has been changed neither tranny was slipping they both drove fine and shift fine the chances that i already had a bad tranny that was workin fine then put another bad one in that works fine would be slim to none
ce1 boy
01-02-2016 08:42 AM
ce1 boy
Transmission & Drivetrain
11-29-2012 06:53 PM
