Engine won't start
Engine won't start
I was driving down the highway and all of the sudden my 2001 Acura Integra cut off I have power the car will turn over but not crank I was driving and then just no engine no Indication at all
Re: Engine won't start
just want to be clear here, the engine does crnk but will not fire, yes? if so, pull the oil fill cap. with someone cranking, check to see if the cams are turning through the oil fill hole.
if they are, CHECK for codes.
if no codes, check the usual suspects:
ignition
fuel
timing
compression
ignition
fuel
timing
compression
TURBO
07-02-2004 10:05 AM
