91 realtime auto wagovan shift position switch issues?
I'm having an issue with the shift position switch in my 91 wagovan. When I turn the car off and put it in park the "P" light in the cluster doesn't always light up. While this happens I can't get the key out of the ignition.
Well, I checked Majestic and it doesn't look like the switch is still available new. I'll call my local dealer tomorrow. For now, I'm wondering if I can just mount a spring loaded rocker switch in the console n tap the green/white wire n run it to ground? Has anyone here had to do this before?
Re: 91 realtime auto wagovan shift position switch issues?
I'm having the same problem with my mom's Del Sol. The key is always getting stuck in the ignition.
I can get it out though, if I disconnect the battery. I'll have to give that switch adjustment a try.
according to this
http://www.ehow.com/how_4537480_test...ontinuity.html
if any of these posts reads anything other than 0 ohms the switch is toast, or can't be adjusted to read 0 , is this correct?
If you look at the pics above posted by RonJ@HT the console switch is the problem.
Heres what i did to fix the switch on my mothers integra.
Removed the switch, removed all plastic covers ( be careful there is a tiny pin ball thats inside) to reveal the contact points for when the switch goes to P, R , N , D , ETC . I noticed that the contact points were dry and did not really make good contact.
I cleaned it up really good. once i did that, i added solder to each contact point to kinda bring it up, or level it up, so that the switch will actually make contact with it. Once finished with that, i lubed it up with electric grease. Put it all back together and haven't had the problem come back. (its been a year).
Sorry i don't have any pics. I spent 5 minutes trying to look for that switch online but i cant find any and I am too tired to keep looking.
according to this
