coolant temp sensor 94 ex
went to the auto parts store and i got my part but i do not know where it is located. it is the coolant temp sensor here is the link to the one i purchased
http://www.google.com/imgres?um=1&hl...23&tx=29&ty=52
could someone please tell me where its located and how to replace it. thanks
Re: coolant temp sensor 94 ex
okay so i finished up the job the other day and the temp gauge works fine now, but car still pulsates idle until the engine is at normal temp, so waht causes this
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
thank you i will do that in the morning. does the need for bleeding the cooling system have anything to do with the temperature of my heater. its semi warm but definately could be hotter
cehcivic15
15
02-22-2010 12:31 PM
