P06 vtec problem
P06 vtec problem
Hi!
I have P06 ecu converted to vtec and with RTP and datalog installed. the engine is f20b dohc.
i used p30 bin file in which i turn off "disable vtec pressure check" and "disable vtec solenoid check" otherwise i get corresponding check engine codes.
datalog showed that vtec turned on but actualy +12 voltage on vtec solenoid pin did not occur. moreover when rpm falls vtec stays turned on until you turn off and then on ignition. i checked out line and get that there is no vtec signal comes to vtec switch (i used ir6220), so ecu did not try to turn on vtec.
Re: P06 vtec problem
I used to have the issue with Crome maps. After i switched to using the Gold map I have not encountered that issue. Crome is a buggy program. If i were you I would purchase a Neptune license since your tuning yourself.
Try using a stock p28 binary file to test the ecu.
If you don't have a vtec pressure switch, perform a bypass via wiring:
http://phearable.net/tech/wiring/vtpsbypass.gif
