Whining noise when pressing gas pedal
Old 10-09-2012, 09:05 PM
Mr2Rotor's Avatar
Default Whining noise when pressing gas pedal
Ok lately I have been hearing this loud whining noise when I press my gas pedal a certain amount. It seems only when I press it half way. Any less or any more and the sound is gone. I'm thinking tranny maybe?
It's a 98 civic with GSR swap and GSR tranny.
Old 10-09-2012, 09:20 PM
CO671's Avatar
Default Re: Whining noise when pressing gas pedal
Where is the sound coming from, it could be from anything. Does it only happen while driving? Does it happen when on idle?
Old 10-09-2012, 09:23 PM
Mr2Rotor's Avatar
Only happens when driving forgot to mention it doesn't make the sound when reving at idle
Old 10-10-2012, 02:29 PM
strategy400's Avatar
Gears are whining? Maybe your bearings are getting worn and the gears are starting to mesh funny. Could be the differential.
Old 10-10-2012, 04:56 PM
freshgear's Avatar
check timing-belt tension.
Old 10-10-2012, 05:10 PM
Mr2Rotor's Avatar
The timing belt can whine? I didn't know that
Old 10-10-2012, 05:17 PM
freshgear's Avatar
is not the timing belt. it is the tension on the belt. if the tension to big it pulls the camshaft to much. have u recently replace timing belt or waterpump check it!!!!!
Old 10-11-2012, 09:44 AM
Mr2Rotor's Avatar
Yes the timing belt was recently changed last month
Old 10-11-2012, 12:34 PM
13g-crx's Avatar
The whining I heard under hard acceleration was coming from the passenger seat. I fixed it by dropping my wife off at the house.
Old 10-11-2012, 12:36 PM
BLKdelSol95's Avatar
nice 13g...mr2, you have a cold air intake on the civic?
Old 10-11-2012, 01:34 PM
Mr2Rotor's Avatar
13g? And no I have a short ram intake.
Old 10-13-2012, 10:32 AM
having a cold air intake or even the short ram you have will pull the air harder than the factory airbox or intake, causing a whistle sound when the air goes past the throttle plate when you press the pedal about 50% down... with the car running, listen for a whistle sound whenever you crack the throttle by hand... ust a theory but that could be what youre hearing
Old 10-13-2012, 11:03 AM
V.MoMO's Avatar
this!
i have this very same sound on my car. stock d16y7 and i modded the stock intake a little and now i get that "whine" sound with my pedal halfway and usually around 2.5-3k rpms. nothing to worry about really and now i have grown to like it
Old 10-13-2012, 11:26 AM
yea so no need to spend any money on parts that dont need replaced
All_JDM_Si
10
10-09-2003 03:30 AM
BnEiAkUiTcY
15
05-30-2002 09:34 AM
eh-D
01-01-2002 04:18 PM
quickLSt
09-12-2001 06:29 AM
Quick Reply: Whining noise when pressing gas pedal
