2012 TSX Wagon......the Graphite Ghost
SunTek clear bra: 18" hood, full front bumper, mirror caps, door cups, headlights.
exLEDusa blue interior LED, white trunk and license.
tinted @ 20% and debadged/rebadged
rebadge
rebadge
Re: 2012 TSX Wagon......the Graphite Ghost
progress RSB 22MM, progress RSL, ES greasable bushings.
CTE Ice box
LED DRL
colormatched: fog bezels and BEAK
swapped in v6 "OPEN" fog vents
3000K HID Fogs
RGB FOG RINGS with Remote
CTE Ice box
LED DRL
3000K HID Fogs
here is a close up of the led ring.
and a shirt from revindustries......who IS a forum vendor check them out/
behind the bumper....notice the OPEN fog vents
been a while......
got some snows from CL/ hankook icebear oem size 225/50r17.....mounted them on my stockers
i also have my nice weather wheels all finished.
work T1S Varianza 19x8 wrapped in conti dws 245/35r19 with tpms
thanks to ken/
teaser until it gets nice......
then i wanted some nice rotors for the wheels
i got some from adam's rotors
pattern = dimple dimple slot
and some ceramic pads from centric posi-quiet
black hub with black zinc coating on surface area.
one box showed today the other will be here next week.
Here is a peek at one front and one rear.......stay tuned for the install
thanks to ken/
the grill is plastic. with proper prep you can make it stick like oem.
something mild. i live in colorado. we can have snow 10 months a year. the roads suck for the most part.
i may just use the tein H springs and bilsteins for the dampers.
dimple dimple slot - my adam's rotors
i did this install in 40 degrees in my dark garage so dont bitch too much about the pics.
also I have only done the fronts so far as it snowed the other day too. and they have not been bedded just yet
I wanted rotors that were completely coated to avoid the rust stripe. I also got dimpled vs. drilled to avoid any cracking.
the pads are posiquiet ceramic direct replacement for LESS DUST.
so I went with adam's rotors. and here is some pics of the fronts.
drivers side
behind the stocker
side by side oem vs adams
ohhhhh ahhhhh
teaser behind my 19s
passenger side
drivers side
behind the stocker
ohhhhh ahhhhh
passenger side
ok so i snuck out this morning for a set of bed in runs. they recommend (10) 60-10-60 stops then a cool down run. they recommend 2 of these.
I did the first 10. i never did that many before but I followed the instructions.
the front look good on the pad surface....mostl;y clean.....the rear look like they need another set...you can see some white looks like pad material. its supposed to snow starting about dusk through tomorrow so the next 10 will have to wait.
cant tell you any improvement in braking yet.......but I do have that slow speed chatter that is common with these types of rotors. i think the dimples cause the noise/
a front
a rear
a front
a rear
V1 w/Blendmount w/Invisicord
V1 that I have owned since 1998....has had a few updates but that was initial purchase date LOL
the left most wire is power and the next is ground. it was all rather simple...
side view: V1 with Blendmount mirror mount and Invisicord wiring direct to the mirror power.
front view
front view
Its a long story so I wont bore you here but
Big Props to Adams Rotors for taking care of me :thumbsup:
these double slot rotors are as quiet as OEM....I do not know they are on except when its important.
I also have the StopTech replacement pads THey are ceramic pads like the OEM ones and I would expect the same wear.
I cant wait to get my SUMMER WHEELS ON!
OK OK some pics :toocool:
the front during install
the rear during install
close up of rear slots
front wheel on ,,,,,stockers with snows.
rear wheels on
I followed adams bedding procedures to the T. I went to an induistrial area on the weekend where no traffic, did my 10 60-10-60 stops and this road is right near a highway entrance so i did the stops and hit the highway 75 MPH for like 15 miles so they get a good cooling off.
here some pics after the bedding
pedal feel is the same in regular driving.....but the bite is there when I need it. I started commuting through downtown to a new gig and had to use these twice already/
i want to now clean them all up and paint my calipers black and get the SS brake lines to increase the pedal feel.
rear wheels on
i did a spring detail....well still working on it.
NO WAX YET or engine detail.
detail sequence
1. Wash CG Citrus Wash Glow @ 5 on the foam gun with sheepskin mitt.
2. Rinse.
3. Wash CG Mr Pink with Fine Clay Mitt.
4. Rinse.
5. Dry: waffle weave with CG Mini Blower.
6. M205 Tangerine Hydro pad.
7. Menzerna SF4500 Red Hydro pad (due to soft paint)
8. IPA 50/50 wipe down 1
9. IPA 50/50 wipe down 2
10. Menzerna Powerlock sealant 1
11. Menzerna Powerlock sealant 2
TO come
12. P21 carnauba
13. P21 carnauba
interior:
Zaino Leather Cleaner
Adam's Leather Conditioner
303 Vinyl Protectant
Invisible Glass
CG New Car Scent
Going to do a touch up under the hood.
and I still need to do the exterior wax/
put the wheels on........springs go in next week so SHAD UP about stance dance :toocool:
a few pics
no poke
center cap daylight
camera flash
detail sequence
2. Rinse.
4. Rinse.
TO come
12. P21 carnauba
13. P21 carnauba
interior:
Invisible Glass
CG New Car Scent
a few pics
no poke
center cap daylight
camera flash
